Question about mixing and pan changes
I have a question that I am sure is easy to answer but I have not been able to find an answer on the web. I have completed some finial mixes for a group and I need to be able to create some performance tracks for them. I have mixed their project in stereo and this will be sent to off for duplication. Now I need to be able to create a peformance CD for them with all the music panned to the left and stack vocals panned to the right to create a split track disc to be used in performance. How can I do this without changing or losing any of the fader moves I have saved for the final mix? Any direction on this would be a big help.
Thanks. --tracy
--tracy |
Re: Question about mixing and pan changes
Hey!
Bounce to disk with the vocals muted and you will have your performace trax. |
Do a "Save Session As..." and give it a new name like "Performance Mix" - then you will have a new session which you can re-tweak all you want, and you can always go back to the other session which will still contain your finished mix automation. This does not duplicate your audio files or anything though, so don't do any permanent deleting or the files won't be there when you switch back!
This might work as well. Bounce your final mix to disk and select MONO, 16 bit, 44.1K. Import the bounce to a new session at the same settings(including tempo). keep the mix panned to one side and add a click track panned to the other side. Bounce that session to create your performance track. I am assuming you want a CD with mono music on one side and click for the drummer on the other side?
Thanks for the tip. I have done most of what you have said, but I really didn't want to redo all the fader mixes in the project. Most of the sessions have at least 24 tracks and some have 32. All I want to do is change the pan for all music left and all backback up vocals to the right. The group uses a mone PA sound system so in their preformance they can run the left side on their mini disc player as high as they need to for music. Then play the right side and different levels for the stack and background vocals. If I make a new project and change to the auto write mode to change the pans, I am going to lose all my fader moves correct??
Thanks again for the help. --tracy
--tracy |
I guess this could work. I could bounce all the music and mute the vocals to mono file. Then mute all the music and bouce the stacks and background vocals to a mone file then marry the two files together. I hoping for an easier way. Thanks for the help. This might be what I have to do.
Thanks, --tracy
--tracy |
Hey Tracy,
Do exactly what you want to do. Pan the music left and vox right. Turn off automation enable for everything except pan just to be sure but changing the pan does not affect the volume automation
IMDB |
Re-Mixing Question | DonaldM | General Discussion | 7 | 01-13-2012 06:05 PM |
Mixing Question ... help! | TDub | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 11-24-2010 11:13 AM |
Question about mixing... | ChuckImania | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 08-10-2008 12:33 AM |
Question on Mixing | LSJ | Pro Tools TDM Systems (Mac) | 3 | 05-09-2008 03:51 AM |
Mixing Question | pete puma | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-11-2001 09:12 AM |
