#131
Re: PT 2024.3 | Released
So right away, I'm having an issue with the "import settings" button in the IO setup. Importing io results in beachball, and requires a force quit. Have tried with several IO templates and this is the case for me all around. Is this a known issue and is there a workaround?
#132
Sharing some thoughts about the new features...
I do find it strange that there is no way to write the MIDI data to a track from MIDI FX like similar to MIDI realtime-properties. How could the newest MIDI process in PT have to be rendered in real-time? It seems antiquated to have to wait for MIDI data to bounce. Well agreed that Avid partially missed the point about the tabs at the bottom of the window. It's great that they can now be moved onto a separate monitor but we still don't want to see them while working at all! Just hoping for MIDI playlists in the next release!!! Most important missing MIDI feature :)
Pro Tools Ultimate 2024.3.1 MacBook Pro 16" Apple M2 Pro with 12‑core CPU, 19‑core GPU, 16‑core Neural Engine 32 GB unified memory 1TB SSD storage Ventura 13.6.4 |
#133
Yes, just upgraded and it's gone. At least my Akai MPK249 still controls Xpand! as far as playing the synths, but I lost transport controls. Not sure why that was removed, and it's not mentioned anywhere in the release notes.
5K Retina 27" (2020) iMac OS 13.6.5 Ventura 3.3 GHz 6-Core intel Core i5 AMD Radeon Pro 5300 4 GB 64 GB 2667 MHz DDR 4 Internal 2TiB SSD Pro Tools 2024.3 EuCon 4.8.6.41 / 2023.11 UA Luna UAD 11 UA Apollo Twin X Avid S1 / Fire10 - 21.8.1.0 PreSonus DigiMax FS 8-input ADAT Dynaudio Monitors PreSonus Temblor 10 Sub Check my Music out here: Paul G YouTube Paul G Bandcamp |
#134
I spoke too soon.
#135
It happens on both wav and mp3. If I increase the buffer size, the problem can disappear, but not yet tried it on enough tracks to see if having max buffer size - because that's what it is currently taking - is a consistent solver of the problem. I'm on HDX, no hybrid processing.
#136
This is a weird one that's new and very concerning for me with 2024.3
Recording to an audio track without first selecting a time region to record to produces a wav file that is not recognised as an audio file by other apps. I've tried Snapper, Zynaptiq Triumph, Zynaptiq Myriad to open the wav file and all fail to open it. If a time region to record is set prior to initiating recording the wav file produced is recognised by the other apps. The files that fail to open in other apps behave as expected in the Pro Tools session as far as I can tell. Recording a track from one or more other tracks via a bus also has the same result so it would appear, at least on my system, that if you record without first setting a time region the wav produced is dodgy. I'm on M1 Mac Studio running PT in native AS mode and my sessions are at 96 KHz 24 bit and audio format is set for BWF(.wav). I haven't tried other sample rates or formats. I've tried trashing preferences since the update but this made no difference to the outcome. Can anybody confirm that this isn't just happening on my system? |
#137
Marianna from Avid noticed a few of us in this forum thread who are having this issue and created a support case for us (thanks Marianna). An Avid Technical Support rep reached out to me for some additional information which I provided yesterday. It appears this was just a bug and the M-Audio controller was not intentionally removed. Avid are looking into it for us…
Intel i7-9700F CPU @ 3.00GHz 32 GB RAM Windows 10 Pro 22H2 M-Audio ProFire 2626 M-Audio Axiom 61 (Gen2) Pro Tools Studio 2024.3.0 Avid Control 2023.11.0.266 |
#138
I just installed it and I have got heaps of popup windows referring to Ozone plug-ins.
It says this: "One of the files this plug-in needs cannot be found, please reinstall or contact technical support for assistance [0x7E] (attempting to load and then it says the plug-in). It appears to be concerning my Ozone plug-in (mainly the RX plug-in). Anyone got a fix that I can try?
Intel(R) Core(TM) i7-9700K CPU @ 3.60GHz 3.60 GHz Windows 10 Pro Pro Tools 12 Fireface UCX |
#139
cheers for this. Turns out they worked with me, and I don't need the functionality due to a work around and all is good. As far as the upgrade goes, so far so good. I only had one weird anomaly that happened twice. PT hung on a plug-in, but after a force quit and re-open it's fine. Other took a long time to open a session that I had just been in moments earlier. I noticed Avid link was complaining about some plugs that needed updating, so I did that and all seems to be well. Another issue was with S1, but I found the doc that gave the instructions on how to fix the issue and again, all is good. I don't know anything about the new midi features. So for what I do, which mostly guitar, fretless bass, vocals, VI Drums, and some pads/keys, I have to say I'm happy with the upgrade. I'm just an old Tele/Les Paul guy who waits for the tubes to get good and hot in the amps before recording. I didn't upgrade to 14.4 Sonoma and will wait for fix. I hear the issue has to do ilok (read in another post). All good here!
#140
I sent you a direct email so please look out for it..... and respond back when you can. Thanks Marianna
Marianna Montague Sr. Dir. CX and Community | Customer Advocate [email protected] cell +1 (813) 493-6800 AOL IM avidmarianna Twitter Avidmarianna We're Avid. Learn more at www.avid.com |
What I would like to see in ProTools in 2024 ! | stevegalante | Pro Tools | 125 | 03-25-2024 12:37 AM |
Runnind PT 10 and 003 Factory with NEW 2024 Mac | PRSWILL | macOS | 20 | 01-18-2024 07:08 AM |
