  #111
Old 03-09-2024, 08:43 AM
junkgear's Avatar
junkgear junkgear is offline
Default Re: PT 2024.3 | Released
Originally Posted by audiogamble View Post
I’m intrigued by the efficiency core optimizations. Ive been hearing reports that this is working on all macos versions and not just sonoma. Is this true?
See post 90
Will
System Details
  #112
Old 03-09-2024, 08:54 AM
nsureit nsureit is offline
Installed HD drivers and PT 2024.3. Everything working great. No issues.
Favorite feature so far is detachable Melodyne and Clip Effects tabs, so I can move to a different monitor.
Dell XPS 15, Win11, MTRX Studio+HDX
  #113
Old 03-09-2024, 10:14 AM
Leigh Marble Leigh Marble is offline
Originally Posted by marianna View Post
Disregard my Facebook ask as I found your case and added to it. thanks for posting this and letting me know. As I said, I updated the case notes and also created cases for those that also commented.
More on Monday.
Marianna
Thank you, I look forward to hearing more.
  #114
Old 03-09-2024, 10:59 AM
Benny_Cha_Cha Benny_Cha_Cha is offline
Hi Ben
I created a case for you on this so we can get to the bottom of it early next week. Case # 04769527
I also added myself to it so I can follow the issue - I did this for others as well.
Marianna
Thanks so much, Marianna!
Ben Rubin
Producer//Mixer//Bassist//Composer
benrubin.com
PT Ultimate 2024.3, Mac Studio M1 Max, 64Gb RAM, Mac OSX 13.6.4, SSD sample drive,
Neve 8816, HD Native Thunderbolt, (2) Lynx Aurora 16, Benchmark DAC-1/ADC-1
  #115
Old 03-09-2024, 11:42 AM
AREED AREED is offline
How about legacy controllers like Icon/C24? Are they still working with this update?
2018 MacMini i7, 10.15
PT 23.9 HDN, 2x192 i/o
D-Command
  #116
Old 03-09-2024, 01:39 PM
off the wall's Avatar
In Rosetta on Mx or on Intel, yes.
offthewallproductions
  #117
Old 03-09-2024, 02:14 PM
moshuajusic moshuajusic is offline
Does "significant performance improvements utilizing Efficiency Cores in M1, M2, and M3" apply to running PT in rosetta? (Boz holding up the works.)
Also, could you guys finally fix the "quick reply" at the bottom of every thread? It still psychs me out.
  #118
Old 03-09-2024, 02:30 PM
aals aals is offline
running in Rosetta mode here
I didn't do any exact tests because unfortunately I read the news about the performance improvement only after installing PT 2024.3, but now I see 16 cores instead of 12 (both Rosetta and Native), and I can play sessions that previously had exceeded the maximum CPU limit so they stopped continuously, now they don't stop anymore
I can't say the exact percentage of improvement, I imagine it also depends on which processor it is, the relationship between efficiency core and processing core
yesterday I did some tests between Rosetta and Native, and, with great surprise, I found that some plugins (to be precise UADx distressor, stereo) are much better performing in Rosetta mode than Native mode... to give an order of ideas, in Rosetta around 300 tracks, in Native around 220 tracks, so the difference is substantial
the interesting thing to do would be to go back to PT 2023.12 and do more "scientific" experiments, but since everything is working well I prefer not to touch anything
  #119
Old 03-09-2024, 02:37 PM
Coffee_Cruncher Coffee_Cruncher is offline
Is anyone else having issue with MIDI playback?
I have a simple session, WA Triaz(native) for drums, UA Electra and Diva. All on stereo Instrument tracks.
I've got a four-bar MIDI chord progression I recorded looped playing the Electra. Triaz is playing its own internal sequence. I am messing around with Diva on top of the other two and have not recorded anything yet. Almost every other time I switch presets on the other two instruments, Electra stops responding to the notes in the MIDI clip. There is also an instance of Scaler on a separate instrument track that I use to pull chords from, but is not playing anything.
It usually gets stuck on the first note then plays nothing. Sometimes it will start playing again mid sequence, some times it needs to be restarted... Some times it takes a few tries to get it play back the chord clip. I tried switching out Electra, still happens with other instruments from different manufactures.
I've tried switching from the MIDI out of the instrument channel from Chain to directly into the instrument. Same problem.
Mac OS 13.6.4, Mac Studio M1 Max, 64GB Ram - All instruments are up to date..... Why can't I edit my old signature?? lol
  #120
Old 03-09-2024, 03:28 PM
rosshc44 rosshc44 is offline
How about command 8? Is that still working on Mac?
What I would like to see in ProTools in 2024 ! stevegalante Pro Tools 125 03-25-2024 12:37 AM
Runnind PT 10 and 003 Factory with NEW 2024 Mac PRSWILL macOS 20 01-18-2024 07:08 AM
