Old 08-21-2007, 03:51 PM
jaynyc jaynyc is offline
Default Splitting/Stretching Midi Notes
This should be simple but I can't figure it out and I tried searching google.. I have Midi Notes I recorded from My keyboard but I would like to edit them in Protools by dividing 1 note into 2..For Example, I have 1 bar in a 4/4 I would like to split it in the middle so theres 1 note up to 2/4 and another note to 4/4 by 2/4..hope that helps .. I would also like to know how to stretch a note.. There is a tool tool to trim down a note (shortcut f6) but is there a way to stretch it and make it longer? For example, I have a note that stops at 3/4..how do i stretch it to 4/4 without changing the beginning position of the note?
Old 08-21-2007, 04:21 PM
Stig Eliassen's Avatar
Default Re: Splitting/Stretching Midi Notes
Click with the selector tool where you want the split, and hit Ctrl-E (PC) or Command-E (Mac).
Err...I think. Check it out and let us know.
Use the trim tool to trim both start and end of the note(s).
Old 08-21-2007, 08:08 PM
the Command E divides it into regions.. i want to seperate the midi note where the selector is in this picture http://tinyurl.com/37fzjo..When I hit Command E the note is still 1 full note but I have new items in the regions list. Also for my other question I wanted to make the note longer instead of trimming it
Old 08-22-2007, 04:52 AM
The trim tool works both ways. You can shorten notes, and you can extend notes with this tool. Can't you make the notes longer?
Command-E didn't work? I'll check at the studio later.
Old 08-22-2007, 09:08 PM
I see I can expand the notes with that tool didnt notice it before..just gotta find out how to split the notes now.. thanks for your help again PTLover
Old 08-24-2007, 02:55 PM
Hmm...I couldn't find a way to split a MIDI note in half. Command-E separates into regions, sorry about that.
So, maybe it can't be done? Any thoughts on the topic?
Old 08-28-2007, 10:14 PM
CapnChem CapnChem is offline
Go to "notes" view, find the appropriate grid value, and draw the two notes instead using the pencil tool.
Old 09-04-2007, 01:37 AM
webby webby is offline
Hey, you could also use the TCE tool on MIDI regions to time compress or expand...
Old 12-04-2007, 02:53 AM
CHRIS AIKEN CHRIS AIKEN is offline
I've been wondering this as well. Is it possible to put the selector tool in the middle of a midi note and seperate it? The same way audio seperates? I know about creating two notes with the pencil tool (my current work around) that's not what I want to do.
I quite often have to seperate a whole multitrack song that contains audio tracks as well as midi...it's a hassle to go and manually seperate and fix all the midi tracks.
Thanks,
Chris
Hackintosh 3.6 GHz 8 Core Intel Core i9 - 12.6.4 Monterey -32 gigs Ram - Carbon - Protools 2024.3 Ultimate
Old 09-08-2019, 05:05 AM
MusicMadness MusicMadness is offline
Hi, has anything changed in this topic for last 12 years? I need to split a long MIDI note into several notes together with audio clip but when I made a common edit group and tried to use CMD+E on both tracks simultaneously, only the first MIDI clip contains velocity information and after deleting it remaining MIDI clips are empty. Any ideas?
PT HD 2018.1, Mac Pro 2013, Digidesign Command 8, Focusrite Clarett 2Pre
Splitting MIDI Notes?? MrWillsi3 MIDI 3 01-01-2010 05:55 PM
Recording Midi notes and keeping existing notes during record Sherbert99 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-15-2008 09:40 AM
Time-Stretching Midi Data??? StinkyStan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-21-2008 10:58 PM
Splitting Midi Notes tonedef MIDI 10 03-25-2006 08:06 AM
splitting notes - please help Digi1newB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-06-2003 07:28 AM
