Old 05-09-2018, 02:33 AM
yl956 yl956 is offline
Default help over lapping clips
everytime i overlap a clip in protools on the same track it cuts off the audio of the previous clip when the other clip starts.. is there a work around this? i just made a transition from sonar to protools and in sonar u can overlap clip ends and they wont cut off they would just play simultaneously.
Old 05-09-2018, 03:07 AM
Stig Eliassen's Avatar
Default Re: help over lapping clips
Welcome to the community.
IMO, this is how a DAW should work. You need to create a crossfade between the clips, and you can make those as long as you want (obviously, within the length of the audio files).
Old 05-09-2018, 09:56 AM
DontLetMeDrown DontLetMeDrown is offline
Yep this is a fundamental difference between how these two daws work. I actually prefer PT’s method since you know that whatever you see on the timeline is what will playback. FYI- you can use playlist view in PT to kind of simulate how Sonar manages layers.
Old 05-09-2018, 10:44 AM
_JJ_ _JJ_ is offline
If you really need the audio to overlap make another audio track adjacent to the first, overlap the clips in the timeline, add fades as desired.
Old 05-09-2018, 11:10 AM
climber climber is offline
what he said...
Al Hospers
bassist, vocal, composer, engineer
https://www.youtube.com/channel/UCCw...ogfR_7Q/videos
PT2023.12, OS X Monterey, Late 2013 MacPro, 6 core, 64 GB RAM, Orion Studio, Slate Raven MTi2, ISA428, ADL600, Distressor, Grace 501, Dimedio, Obsidian, One LA, BAC500, Harrison 32 EQ, UAD2 OCTO, Focal 6 be, Auratones...
Exporting Clips as WAVs, clips dont highlight in list gigantorbuzz Pro Tools 10 6 08-05-2013 01:07 PM
Cross fades are not between clips but at the end or beginning of clips phatbeatstudio Pro Tools HDX & HD Native Systems (Mac) 2 09-10-2012 02:08 AM
Drag Clips = Delete Clips??? Connor macOS 2 07-09-2012 07:50 PM
Editing clips without creating new clips dimebagslash Pro Tools 10 2 07-04-2012 07:24 AM
over lapping audio files without creating a pause remusjacobs Pro Tools 9 2 12-20-2011 07:28 PM
