Old 01-21-2003, 09:14 AM
CircleMusic CircleMusic is offline
Default Allocating Memory to ProTools and DAE
I have a G4 450 and I am trying to use more than 4 midi channels with the SampleTank plugin. I have no problems with this many channels while the sessions is open, but if I try to re open a sessions that has the SampleTank plugin active my system hangs indefinitely. The sessions never opens and I must the do a forced restart. I think I need to allocate more memory to PT and DAE I dont know how to do this HELP! [img]images/icons/confused.gif[/img]
Old 01-21-2003, 02:30 PM
Default Re: Allocating Memory to ProTools and DAE
Come on people! I know it is a stupid question but I seriously dont know that much about Macs
Help!
Old 01-21-2003, 02:53 PM
Thresholdproductions Thresholdproductions is offline
Go to your protools application icon and click Command(apple button) "I". This will give you info on the icon or application on this case. Then go to memory on the pull down bar and allocate more memory. Also do this for your DAE. DAE doesn't need as much memory as protools does. Dae will be in your systems folder while protools will probobly be in your apps folder or whereever you installed it to. Forget everything I said when we move to OSX as OSX determines how much memory an app gets by what it needs at a given time.
Good luck
Old 01-22-2003, 06:19 AM
Thanks Thresh! I will try it out tonight
Old 01-22-2003, 07:16 AM
where02190 where02190 is offline
See "adjusting your memory usage" from the Mac os help menu, or type in memory in the help search screen. It will give you step by step instructions.
Reading is fundamental.
Hope this is helpful.
Allocating memory,PT Won't let me !! rgriff 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-23-2005 10:36 AM
Allocating Memory ahamay 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-02-2003 07:08 AM
allocating more memory to PT daven Pro Tools TDM Systems (Mac) 2 10-15-2002 02:28 PM
Allocating more memory Saxappeal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-13-2001 11:58 PM
Allocating memory to Pro Tools Zapakos 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-13-2000 03:51 PM
