help using 48 samples (buffer size)
is there any way to use a buffer size of 48 samples in pt 2018..when i load at that sample rate pt says that its not supported is there any way around this
Re: help using 48 samples (buffer size)
I believe you have misunderstood something somewhere.
Sample rates are 44.1khz / 48khz / 88.2khz / 96khz ect. Buffer sizes are 32 / 64 / 128 / 256 / 512 / 1024 all in samples. As Buffer sizes increase you audible latency will increase.
Do you really mean 48 samples buffer, or do you actually mean 48K sampling rate? A buffer of 48 samples is highly unusual. Typically you'll find buffers available at 32, 64, 128, 256 et al. Anything outside of this is not handled well at all via an ASIO driver. If you actually mean a 48K sampling rate, then the reason you may not be able to select it is that Windows is using your interface and doesn't like to share. The default Windows audio device should be the onboard audio on your PC, not the audio interface. So changing Windows back to the onboard device will leave your interface freely available for unrestricted use in Pro Tools. Sent from my iPad using Tapatalk
yea I meant 48 buffer size... i run a babyface pro on fl studio with a buffer size of 48... but protools wont allow that buffer size i get an error message saying its not a supported buffer size
This is correct. Use 64 samples(if available) for tracking.
HW buffer size 64 samples..?.. | Codo | Pro Tools TDM Systems (Mac) | 2 | 11-01-2011 03:58 PM |
32 Samples H/W Buffer Size playback with 192 I/O | MikeLip | Pro Tools HDX & HD Native Systems (Win) | 16 | 09-10-2011 12:36 PM |
can't change h/w buffer size above 128 samples | mmiller | Pro Tools M-Powered (Win) | 6 | 07-24-2010 10:42 AM |
HELP....H/W Buffer Size @ 128 Samples or less DOENS'T WORK AT ALL | rogerhavoc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 12-31-2002 05:17 PM |
My whole system crash when i set my H/W Buffer Size @ 128 Samples or less | rogerhavoc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-29-2002 02:50 AM |
