Old 03-03-2018, 10:35 AM
sambosun sambosun is offline
Default Toggle between Mute/Solo
Does anyone write a feature request about this simple feature already?
Basically all DAW I work with (Logic/Cubase etc) allow to solo a muted track/channel and if I un-solo it that track/channel will mute again.
I know workarounds to that and just wanted to know if feature request regarding that where already send.
Thanks
Old 03-19-2018, 12:13 PM
Xcurve Xcurve is offline
Default Re: Toggle between Mute/Solo
I'm trying to do the same thing. I assume you are using Pro Tools but you mentioned other DAWs. If I was start a new post I would say "Soloing a Muted Track." Anyone know how to do this? Thanks.
Old 03-19-2018, 02:43 PM
Here's a work-around you probably have not thought of. As long as you have an extra pair of outputs available, add a send to the last send slot on every track. Make it pre-fade, fader to -0 and muted. Now, instead of using the SOLO button, Ctrl-click on the send(and feed this output to phones or a separate set of speakers). This solves your specific wish, but also allows some other(and very useful) options, like listening to FX tracks without the sending tracks
Old 05-25-2018, 09:57 AM
yuyu yuyu is offline
Enable Track and Edit Selection.
Put cursor on the track of interest.
Solo (or mute) the track.
Hold SHIFT and press S and M simultaneously.
That will toggle the track state between Solo and Mute.
Old 03-26-2020, 08:38 PM
DFT DFT is offline
I am not sure if this is what the OP was asking for ...
I have soloed a track.
I now wish to solo a different track.
I'd like to be able (using some key stroke shortcut or preference) to have the first track unsolo (go to mute) when I solo the different track.
Is this possible?
PT10 Win7 x64 Dell 690P Dual Dualcore Xeon 3.0Ghz 16Gb Ram, UAD2 Quad (2), Steinberg MIDEX8 (2), RME HDSPe and A&H ZED R16 FW.
Old 03-26-2020, 08:55 PM
Top Jimmy's Avatar
Is this possible?
Options > Solo Mode > X-OR
James Cadwallader
Old 03-27-2020, 05:00 PM
DFT DFT is offline
Top Jimmy!
Besides thanking you for the instant help, thank you even more for giving all the time and effort required to moderate!
DF
Old 03-27-2020, 05:30 PM
Top Jimmy's Avatar
Top Jimmy!
DF
You’re welcome. :)
James Cadwallader
Old 04-02-2020, 10:03 AM
LeoP LeoP is offline
That's a feature I'm thinking of often lately. It would be very useful, like when muting the guidetrack while editing ambiences and then listening to the guidetrack in solo for comparison on the center channel.
Anyway, the shift S+M is a good suggestion, probably with a little macro/soundflow stuff that can be made even faster and automated on a single keystroke.
Send mute/solo follows track mute/solo pre-fader Roger_Jam_Jet Windows 3 09-24-2017 01:59 PM
12.6 Bug Test Mute Toggle strangepumpkin Pro Tools 12 11 01-23-2017 08:24 PM
Can't solo or mute (bug?) mdb Windows 5 05-10-2013 10:29 AM
Protools 10: mute and solo aren't working. (Solo safe is not on any of the tracks.) charlottewrinch macOS 2 04-14-2012 05:32 PM
keyboard shortcut to toggle solo? DaveBCC 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-15-2011 07:34 PM
