Old 11-11-2015, 08:23 PM
Siegfried Meier Siegfried Meier is offline
Default Commit Tracks and HEAT
Hey guys,
Does Commit Tracks include HEAT in the process? Or not?
Old 11-11-2015, 08:39 PM
Default Re: Commit Tracks and HEAT
I just tried a null test, it appears that it does not! Good to know.
Old 11-11-2015, 10:26 PM
Wall2Wall Wall2Wall is offline
My recollection is commit does include HEAT in pre only.
Old 11-12-2015, 07:20 AM
I'm using it in post, and it doesn't either.
Old 11-12-2015, 08:05 AM
From the manual. Only in Pre does HEAT commit.
What Gets Committed
Committing a track always renders the following:
• Clip Gain
• All Inserts (or Commit to Insert)
• HEAT, if Pre-Insert (Pro Tools HD only)
• Elastic Audio
The following source track data is always copied to
the new track when committed:
• Timebase
• Elastic Audio Algorithm
• Solo Safe
• Track Input assignment (unless the channel
width changes)
• Track Output assignment
• HEAT settings (Pro Tools HD only)
Old 11-12-2015, 08:56 AM
dtmprod dtmprod is offline
I didn't realize there was a 'pre' & 'post' setting. Does anyone know if it makes a diff in overall sound? Reading thru manual indicates that it 'defaults' to pre setting. But in looking at my system, audio tracks seem to default to post. Which is probably better for the way I work, since I like to put any native plugins first before DSP. Apparently using native plugs in 1st slot uses extra voices when Heat is set to 'pre'. Maybe I need to send Dave a note to help explain all this…..
Old 11-13-2015, 08:47 AM
What Gets Committed
• Clip Gain
• Elastic Audio
• Timebase
• Solo Safe
width changes)
Awesome, thanks for the info dude!
Old 11-13-2015, 08:51 AM
JFreak's Avatar
JFreak JFreak is offline
I always use pre HEAT
Janne
Old 11-13-2015, 10:21 AM
The Weed's Avatar
The Weed The Weed is offline
Pre HEAT makes sure the oven is hot enough to bake. Mmmmmmmm cookies!
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 11-13-2015, 10:45 AM
29CountsNY's Avatar
29CountsNY 29CountsNY is offline
From your username I thought you were going someplace totally different with that one!! LOL!
www.montabonsound.com
www.29counts.com
Pro Tools HD 2019.12 | HD Native PCIe & HD Native Thunderbolt | Lynx Aurora 16 HD | HD I/O | Digi 192 | 2010 Mac Pro 12 Core 3.46ghz | macOS Mojave 10.14.4 | 48 gigs RAM | Tascam DM3200 | Crane Song Avocet II | Antelope Isochrone OCX | Universal Audio Quad & Duo | Waves Mercury + Studio Classics v10 & Abbey Road Collection
SSD and 12.3 commit harryk Pro Tools 12 11 11-08-2015 09:49 AM
Does comping to a Heat enabled track print the Heat? joshdrucker macOS 0 03-12-2014 10:17 PM
To Commit or not to Commit, that is the question. georgejw22 Pro Tools 10 10 12-20-2011 05:30 AM
HEAT on stereo bus as well as tracks Picture Start Pro Tools TDM Systems (Mac) 11 11-22-2011 10:56 PM
Heat on Aux Tracks? Bus output to Audio Track? Rule62 Pro Tools TDM Systems (Mac) 9 09-19-2011 09:22 AM
