Authorization code won\'t work
I just reformatted my hard drive and reinstalled everything. When I launched Pro Tools for the first time it asked me for my authorization code, but for some reason it keeps telling me my code is invalid.
I really don't know what to do. I called Digi, but they're not taking calls right now because "they're experiencing an unuasually high volume of traffic." Can anyone help me? I must be doing something wrong. But I've tried entering the code multiple times, and I've double and triple checked to make sure it's right. I'm using the code on my QuickStart sheet that is in this format: PN xxxx-xxxxx-xx REV A 11/06 I even tried using the code on the inside cover of my Getting Started PDF, and the code in my Upgarading to 7.0 PDF, but none of them have worked! PT 7.1 MBOX Mini Dell Inspiron 6000 |
Re: Authorization code won\'t work
The correct code starts with DIGI0 and is case sensitive.
It's been reported here that the code for the Mini is now located on the install disc paper sleeve. Prior to that it was always on the inside cover of the Getting Started manual. |
PT LE 7.4 Authorization code doesn't work | 51sth | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-05-2012 08:33 AM |
Authorization code wont work! | deeceechillen | General Discussion | 5 | 05-11-2010 07:59 AM |
Upgraded to 7.4.2 and now my authorization code doesn't work | ryanm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 06-23-2008 10:13 AM |
Upgraded to 7.4.2 and now my authorization code doesn't work | ryanm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-22-2008 09:18 PM |
Authorization code will not work | Da' Cono Men | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-12-2005 08:34 PM |
