Old 05-15-2019, 05:02 PM
fsavell fsavell is offline
Default Unresponsive / sleepy fader fix
Other than power cycling the S3, has anyone found a solution to wake up unresponsive faders?
Forrester
Old 05-16-2019, 07:41 AM
EddieJones's Avatar
Default Re: Unresponsive / sleepy fader fix
Are you running the latest soft/firmware ?
Old 05-16-2019, 08:47 AM
Gordon Hookailo's Avatar
Gordon Hookailo Gordon Hookailo is offline
Forrester
Sometimes the S3/Dock/Control will get all wonky (a fader not working or o-leds getting dim). S3 sometimes shows wrong info for a send (like the send is on when it's not). The fix here is to power cycle all eucon devices. The power switch on my dock doesn't turn off the dock! I have all on one power strip to make restarting easier.
Rig #1:
Mac Pro 5,1 12 core 3.33ghz 32gigs RAM / OS 10.14.6 / SSDs, NVMe, 2) RAIDS & other drives / Sonnet USB3 Card, ESATA Card / MOTU UltraLite-mk3 Hybrid firewire / HDN PCIe card 192 IO. S3 / Dock / Avid Control Running PTs 2023.6 Eucon 2023.6
Rig#2
Mac Pro 3,1 8gigs RAM / 10.6.8 Pro Tools HD3 192 / 888 Running PTs 8
Old 05-22-2019, 05:54 PM
Hey Eddie, yes running 19.5.0.514REL and PT2019.5 Ultimate HDX2. Its been happening since I bought the S3 though.
Its not often (maybe twice per week) that a fader completely stops responding. Doesn't matter what mode I change the S3 to, whether its viewing sends, faders or what tracks are selected. As far as I can tell, its a different fader every time, so I'm not too concerned that its necessarily a faulty fader, mostly likely a software thing? But it completely stops responding until I power cycle the S3. Haven't found any software solution to reset this issue.
Right now whatever that fader is set to, doesn't not respond at all (i.e. no volume control on that track).
Forrester
Old 05-23-2019, 09:10 AM
EddieJones's Avatar
Usually, they stop once they lose contacts (dirt on the tracks). keep an eye out and make a note of which noes and see if there's a pattern. You could try blowing some air down the ones that fail the most.
Old 05-23-2019, 09:22 PM
Thanks Eddie, i'll try that next time.
Old 07-17-2019, 04:13 PM
Rajsmoove Rajsmoove is offline
Get some contact cleaner from Lowes or Home Depot
I had a sleepy fader that I replaced a few years ago. Then another one started dropping off. I ordered two extras and as soon as they came, the fader started working again, then would randomly fall off but it was never completely dead. I worked in some contact cleaner and it has been solid for the last few weeks. Hope this helps somebody else!
D-Control Fader-Unit is unresponsive!! freeBase ICON & C|24 5 12-11-2014 08:41 AM
Mute / Volume Fader Unresponsive blizzard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-29-2006 07:37 PM
Sleepy the Firewire Drive RussUK 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-25-2005 12:38 AM
Sleepy Mac??????????? trakbytes Pro Tools TDM Systems (Mac) 2 03-30-2003 04:05 AM
Sleepy plugs thermoboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-22-2002 03:55 AM
