OT change drive letters
When I unplug my drive the labels change on the devices... so I would like to make my cdrw read teh letter "Z" how do I change the drive letter in XP pro
Re: OT change drive letters
right click my computer
click manage go to disk management right click on the volume (or device in the case of a CD drive) click change drive letter and paths the rest is pretty self explanatory
Cavell Studios |
Thanks
I just found this in windows help and support on the computer.
To assign, change, or remove a drive letter Using the Windows interface Open Computer Management (Local). In the console tree, click Disk Management. Where? Computer Management (Local) Storage Disk Management Right-click a partition, logical drive, or volume, and then click Change Drive Letter and Paths. Do one of the following: To assign a drive letter, click Add, click the drive letter you want to use, and then click OK. To modify a drive letter, click it, click Change, click the drive letter you want to use, and then click OK. To remove a drive letter, click it, and then click Remove. Important Be careful when making drive-letter assignments because many MS-DOS and Windows programs make references to a specific drive letter. For example, the path environment variable shows specific drive letters in conjunction with program names. Notes To open Computer Management, click Start, point to Settings, and then click Control Panel. Double-click Administrative Tools, and then double-click Computer Management. You must be logged on as a computer administrator in order to complete this procedure. A computer can use up to 26 drive letters. Drive letters A and B are reserved for floppy disk drives, but you can assign these letters to removable drives if the computer does not have a floppy disk drive. Hard disk drives in the computer receive letters C through Z, while mapped network drives are assigned drive letters in reverse order (Z through B). You cannot change the drive letter of the system volume or boot volume. An error message may appear when you attempt to assign a letter to a volume, CD-ROM drive, or other removable media device, possibly because it is in use by a program in the system. If this happens, close the program accessing the volume or drive, and then click the Change Drive Letter and Paths command again. Windows 2000 and Windows XP allow the static assignment of drive letters on volumes, partitions, and CD-ROM drives. This means that you permanently assign a drive letter to a specific partition, volume, or CD-ROM drive. When you add a new hard disk to an existing computer system, it will not affect statically assigned drive letters. You can also mount a local drive at an empty folder on an NTFS volume using a drive path instead of a drive letter. For more information, click Related Topics. Using a command line Open Command Prompt. Type: diskpart At the DISKPART prompt, type: list volume Make note of the number of the simple volume whose drive letter you want to assign, change, or remove. At the DISKPART prompt, type: select volume n Select the volume, where n is the volume's number, whose drive letter you want to assign, change, or remove. At the DISKPART prompt, type one of the following: assign letter=L Where L is the drive letter you want to assign or change. remove letter=L Where L is the drive letter you want to remove. Value Description list volume Displays a list of basic volumes on all disks. select volume Selects the specified volume, where n is the volume number, and shifts the focus to it. If no volume is specified, the select command lists the current volume with focus. You can specify the volume by number, drive letter, or mount point path. On a basic disk, selecting a volume also gives the corresponding partition focus. assign letter=L Assigns a drive letter, L, to the volume with focus. If no drive letter is specified, then the next available drive letter is assigned. If the drive letter is already in use, an error is generated. remove letter=L Removes the drive letter, L, from the volume with focus. If no drive letter or mount point is specified, then DiskPart removes the first drive letter or mount point it encounters. The remove command can be used to change the drive letter associated with a removable drive. You cannot remove the drive letters on system, boot, or paging volumes. Notes To open command prompt, click Start, point to Programs, point to Accessories, and then click Command Prompt. You must be logged on as a computer administrator in order to complete this procedure. A computer can use up to 26 drive letters. Drive letters A and B are reserved for floppy disk drives, but you can assign these letters to removable drives if the computer does not have a floppy disk drive. Hard disk drives in the computer receive letters C through Z, while mapped network drives are assigned drive letters in reverse order (Z through B). You cannot change the drive letter of the system volume or boot volume. An error message may appear when you attempt to assign a letter to a volume, CD-ROM drive, or other removable media device, possibly because it is in use by a program in the system. If this happens, close the program accessing the volume or drive, and then click the Change Drive Letter and Paths command again. Windows 2000 and Windows XP allow the static assignment of drive letters on volumes, partitions, and CD-ROM drives. This means that you permanently assign a drive letter to a specific partition, volume, or CD-ROM drive. When you add a new hard disk to an existing computer system, it will not affect statically assigned drive letters. You can also mount a local drive at an empty folder on an NTFS volume using a drive path instead of a drive letter. For more information, click Related Topics. For more information about DiskPart, click Related Topics. Related Topics BLAH BLAH BLAH...Chris said it in a lot less words.
Bazzle |
Beat ya to it!
Cavell Studios |
You da Man
Bazzle |
Rehearsal letters??? | northernbird | Pro Tools 10 | 1 | 12-04-2012 07:13 PM |
Workstation Name letters & numbers, how do I change it? | Mike Thornton | Artist Series | 1 | 06-06-2012 09:36 AM |
Keyboard Letters On/Off | LynorEclipse | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-20-2010 10:11 AM |
Swedish letters (å ä and ö) in Pro Tools Le 7.1 | Luzer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-20-2006 11:11 AM |
More "groups" then letters available. | NK | Pro Tools TDM Systems (Mac) | 0 | 07-11-2005 10:41 AM |
