Omni line-level in on front panel 1-2
I'm doing some analog transfers from a quarter-inch tape machine (Otari 5050B) to Pro Tools HDX through an Omni interface. I can get a signal to the TRS 1-2 inputs on the back of the Omni just fine. My question is can the combo XLR/TRS jacks on the front of the Omni labeled 1-2 be used instead? It would be much more convenient than getting in the back of the rack all the time. I've tried without success to get a line-level signal into Pro Tools from the front panel. I've tried XLR, then TRS switching the input selector to mic, then line. No luck. Am I missing something? Thank you in advance.
Michael McDonough, M.P.S.E. Michael McDonough Sound Design |
Re: Omni line-level in on front panel 1-2
No.
You have a Omni HD Guide PDF? |
What he so eloquently tried to say is front panel combo is mic/instrument and cannot be used with line-level sources. Doing a quick search for a manual usually clears out this kind of confusion.
Thank you for your quick reply. I'm glad I was eloquent! I actually did research in the manual before I posted but maybe I was looking for functionality in the front panel that simply was not designed in. Too bad though. It would be very handy to be able to plug in a line-level source from the front as well as a mic.
I can imagine the product meeting... “we’ll put a mic and DI input on the from for convenience in the control room, and a line in on the back, to use for permanently wiring stuff in..”. arrgggg...
It would be too much engineering to let end user choose if he wants to use line-level inputs from the front panel or back
You could always use a pair of direct boxes into the front XLR inputs, or get some inline pads. I would probably just bring all the rear connections to the front of the rack with a patchbay, or a simple panel.
Of course, but that wasn't the point. Besides, I like to do my panels myself using quality Neutrik components so simply Omni panel would cost like a hundred, counting zero value for the work involved.
If all that the end user wants is inserting 1-2 as line-level and have a switch to toggle between line/inst levels, that apparently costs too much to engineer in as a feature.
Can you make front panel mic line level | paullb1 | Eleven Rack | 3 | 07-22-2017 07:36 PM |
Front panel problem w HD Omni interface? | jppp26 | Pro Tools HDX & HD Native Systems (Win) | 2 | 08-09-2014 05:24 PM |
Source selection on OMNI via front panel - is it possible? | propower | Pro Tools HDX & HD Native Systems (Mac) | 1 | 07-11-2013 06:49 PM |
Front Panel DI on 003+ not working. | azuraman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 07-13-2009 03:29 PM |
OT, different colored front panel for 001 ???? | Bob Legs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 15 | 07-19-2003 12:33 AM |
