Old 12-16-2012, 01:11 AM
peterle peterle is offline
Default Mix on Mac: Only Router as Workstation ???
Setup: Macpro OS 10.6.8 , Eucon 2.6.2 , PT HD 10.3.2 , Avid Mix
Ethernet Port 1 = Artist Mix , Automatic IP
Ethernet Port 2 = Router (internet+maybe printer)
Since installing a new Router i have on my PT rig the problem
that eucon software doesnt recognizes my user-account on
my mac as a workstation when the router is connected while bootup,
instead it shows up only the router
as workstation and refuses to connect to protools.....
My User Account even doesnt show up on the list of available
workstations in eucon , only the router.
Onliest solution was physically disconnect the Router from Port 2
while bootup , then shows my user-account as workstation up ,
start protools , configure Eucon , THEN connect router etc.
Is there any solution for this problem?
BTW i tried in between to configure a printer , attached via usb to the
router , as network printer ( the printer failed and i deleted the network
printer later ( ipxxx/printer/printserver/) ... but maybe eucon gets
confused about a printserver ???
foley artist , soundeditor
Old 12-16-2012, 09:11 AM
Default Re: Mix on Mac: Only Router as Workstation ???
... meanwhile i changed the artist mix successfull to static IP,
but same symptom that only the router shows up as workstation...
any ideas?
MC MIX/Control Router Issue... micline Artist Series 4 09-16-2011 01:36 PM
Router wifi in FOH kalunga VENUE Live Sound Systems 1 11-29-2007 07:41 PM
looking for a router baadc0de Pro Tools M-Powered (Win) 0 05-10-2006 11:01 PM
OT - Linksys router problem. graveleye 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 16 06-14-2004 01:47 PM
using MOTU Midi router with PT on a PC Steve Moore MIDI 1 06-17-2003 10:06 AM
