Old 11-03-2002, 02:48 PM
Xabi Xabi is offline
Default 25fps into 24fps?
Hey,
I have a 5.1 audio files in 25 fps, I want to make a conversion into 24 fps to be in sync with film (35 mm).
There is a computer assisted solution to do that ? There is a program who REALLY works ?
My 5.1 audio files program is 18 minutes long.
Thanks
Xabi PERY
Laguna Studios
64200 Biarritz - France
Old 11-04-2002, 03:10 PM
Doug the Brit Doug the Brit is offline
Default Re: 25fps into 24fps?
Pitch'n Time by Serato!
"You only need two tools; WD40 and duct tape. If it doesn't move and should use the WD40. If it moves and shouldn't reach for the tape."
HTML code is On
24fps to 25fps audio first ? barakka Post - Surround - Video 6 07-17-2013 02:14 AM
Using 25fps to 24fps then the converted 24fps to new 25fps. Stay with me on this! abes Post - Surround - Video 2 03-01-2013 09:36 AM
25fps to 24fps help needed Reckless Erik Post - Surround - Video 8 11-13-2009 07:39 PM
25fps - 24fps - Help! paulspurrier Post - Surround - Video 1 10-03-2004 02:36 PM
Going from PAL 25fps to Film 24fps Bokir Post - Surround - Video 6 04-03-2003 02:59 PM
