Assigning individual MIDI channels with Kontakt
Happy Holidays, all!
I received the Garritan Personal Orchestra as a Christmas present yesterday. I'm using it as a RTAS plugin through Kontakt Player. The Kontakt Player allows up to eight instruments to be loaded at a time, each can be assigned to it's own MIDI channel. Here is the problem: I don't seem to have the option of specifying an individual MIDI channel when selecting the Garritan Personal Orchestra on a Pro Tools MIDI track. When I activate the MIDI output dropdown box, I see the option 'Garritan Personal Orchestra 1' but it doesn't allow an individual channel to be selected. The MIDI data is always routed to channel one. All the other MIDI routing options within the dropdown have an arrow on the right-hand side that, when hovered-over, offer a list of 16 individual MIDI channels for that device. Am I missing something? Thanks, |
Re: Assigning individual MIDI channels with Kontakt
Kontakt RTAS requires multiple instances of Kontakt to be inserted on separate tracks. Each inserted instance on each aux track will create another midi channel which corresponds only to the instantiated Kontakt insert. In other words, Make an aux track, insert Kontakt. Create a midi track and you will have Kontakt midi channel 1 which related to this instance on the aux. For instrument 2, do the same thing, only now the Kontakt midi channel 2 relates to the 2nd instance of Kontakt.
The Kontakt engine uses very little CPU overhead so you are not terribly penalized. I ran 8 instances of Kontakt with no instruments loaded, and it used almost the same amount of CPU.
Cliff Stendel -iMac 5K 32g
-PT12. HDX -HD I/O 8x8x8. -HD Omni -Avid S3 -API 2500 -API 5500 -UA 2-1176 -UA 2-610 -Neve 1073, Chandler LTD-1 -Eventide H8000FW -Lexicon PCM96 -Bricasti M7. -Joe Meek channel. -Waves Mercury, Flux all, Softube All, Plugin Alliance all, McDSP all, Sonnox All, MH production, Wave Arts,a bunch more -Moog Voyager XL, Nord Piano, Hartmann Neuron, ARP Axxe, Gibson Les Paul, Mesa Boogie Roadster, Kemper, Taylor T5 and T5-12 |
To use multiple MIDI channels.. and improve your timing.. use the FXpansion VST->RTAS wrapper.
Be aware tho' I think there may be a bug with the VST version of Kontakt which distorts one side of the triggered sample. Rail
Assigning midi channels from structure essentials to axiom 49 | djguitarboy23 | Pro Tools M-Powered (Win) | 0 | 01-18-2011 06:17 PM |
assigning different instruments to different midi channels | jsbrown | MIDI | 1 | 12-14-2008 01:19 PM |
Assigning Midi channels to notes | William 2014 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-11-2005 03:03 PM |
Assigning Midi Channels | skyhawk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-14-2003 09:44 PM |
Assigning MIDI tracks/channels | KT | Digidesign Hardware & Software | 1 | 10-17-2001 06:49 AM |
