Assigning Midi Channels
So here is my problem...I'm creating my very own ring tones for my Nokia phone. I create the tracks in Reason- then export them as a midi file into Pro Tools and then assign the appropriate patch numbers from the General Midi guide...it works great except for the drumkit. I see no drumkits on the GM guide. I've read that midi channel 10 is specified for the drumkit.
So my question is how do I assign my midi drum track in Pro Tools to this channel? (I can assign the drum tracks in the Qucktime Player, but once I save it, it is no longer recognized as a midi file by any apps- including the phone.) thanks |
Re: Assigning Midi Channels
Hi skyhawk,
when you say "saving the file" do you mean saving the file!??? If so, this is why it's not working, saving it saves the session. If you meant "bouncing" it is also a no go since your file becomes an aiff wave(or whatever it was set to save it as) You have to export MIDI, and don't forget to add the ".mid" extension Hope this helps Ben
"Sorry! I didn't hear you. WHAT DID YOU SAY!" PTLE 5.1.1 Digi001 MacOS9.2.2 Yikes!400MHz |
I figured it out now...not in Pro Tools, but with the Quicktime Player.
And as far as your point about saving- I was exporting midi from Pro Tools- my question was how to assign channels to certain midi tracks. Thanks for the response |
Assigning midi channels from structure essentials to axiom 49 | djguitarboy23 | Pro Tools M-Powered (Win) | 0 | 01-18-2011 06:17 PM |
assigning different instruments to different midi channels | jsbrown | MIDI | 1 | 12-14-2008 01:19 PM |
Assigning Midi channels to notes | William 2014 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-11-2005 03:03 PM |
Assigning individual MIDI channels with Kontakt | bousley | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-26-2003 01:16 PM |
Assigning MIDI tracks/channels | KT | Digidesign Hardware & Software | 1 | 10-17-2001 06:49 AM |
