LE/LOGIC/MTP-AV(USB) crashes....
symptoms:frequent crashes w/no error codes.
when i first got 001 I thought it was logic/001 issue but I 'm starting to believe it is logic/mtp-av, particulary USB. it seems to happen when I use my keyboard too fast. start, stop etc...any doctors out there? |
Re: LE/LOGIC/MTP-AV(USB) crashes....
If you've got OMS 2.3.8 in your system - then that's the most likely cause. I'm about to swap my MTP AV USB for a Unitor since the AV can't work without OMS (unless Emagic pulls off some miracle in the next few weeks!). OMS has always been problematic with Logic.
There is a beta of Freemidi available which has a new OMS USB driver for Motu interfaces - it seems to cure a multitude of sins. The address is available in Mac Protools forum under "USB midi with lots of holes" or something like that!
------------------ Ciarán Cahill Music, Macs n'Stuff.
Ciarán Cahill Music, Macs n'Stuff. |
you know it was down to those two and I choose the mtp-av.. I got the- G3/plat 4.../mtp-av/001/all right when they first came out I have been through it all i hope that all this is going to be cleared up soon I'm so fed up.
lesson : Wait until they iron out the bugs. thanx you guys for your help. |
002 crashes Logic and Cubase | LargeEars | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-07-2004 02:04 PM |
AudioSuite crashes Logic 6.1 in OSX | Lee Blaske | Pro Tools TDM Systems (Mac) | 1 | 09-06-2003 09:31 AM |
Logic 5.0.0 crashes all the time.. Is there a Logic expert around here? | uno1234 | Pro Tools TDM Systems (Mac) | 13 | 04-28-2002 04:23 PM |
Crashes OS 9.1& DP -PT -Logic | JLEpperson | Pro Tools TDM Systems (Mac) | 0 | 04-24-2001 07:37 AM |
Logic Crashes DAE since 5.0.1,anyone else? | Stratman | Pro Tools TDM Systems (Mac) | 5 | 07-07-2000 07:34 AM |
