#31
Re: Why does consolidation &or bouncing tracks=loss of sound quality
Nobody complained about bouncing tracks in analog.
#32
I'd like to raise an issue about Phase-invert comparisons.
Nobody ever says that they hear anything at all when they try this test. The silence is always taken as proof positive that the two files are identical in every respect except absolute phase. Because this would be the case with two analogue files, the assumption is made that it's also true for digital files. I would contend that it may not be true. If the files are bit-for-bit identical, you would assume that they should sound the same, and if there are any differences in the bits, they should sound different. But suppose the bit differences are at the very bottom of the signal's resolution: the bottom few steps of the sampling ladder. The phase inversion trick becomes a bit of a blunt instrument when trying to pick out -144dB signals amongst convertor noise. You'd be hard-pressed to hear them, in other words, especially if they were randomly distributed. Yet this very low-level information difference may be just what's contributing to a feeling that the files sound different. Furthermore, it's now generally accepted that clock accuracy has a big influence on sound quality. There may be timing errors - jitter - introduced by bouncing to disk. These errors may not be made audible by the phase-invert test, but could make two files sound different. In short, I would suggest that there could be many artifacts within a bounced file that simply do not show up with the phase-invert test. The only sure way to determine what's happening is to compare files on a bit-for-bit basis. (Discuss, 30 marks) |
#33
interesting doug...
narcoman |
#34
#35
#36
best, rich
http://www.richbreen.com ---------------------------------------- Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6 |
#37
We're finishing our first 5.1 project and we started bouncing the mixes today.
I was shocked to listen to the resulting files. They sounded dead comparing to the original PT session, and worst of all, the 2 surround channels are about 5db lower in level! Does anyone have any similar experiences with bouncing 5.1 mixes? Izhar PT HD3, 5.3.1. |
#38
PT, I hate the sound of those molecules banging together, especially in the morning after a bottle of malt whisky [img]images/icons/smile.gif[/img]
John, I wouldn't doubt that the cumulative effect of minor distortions could be a problem over many tracks, in the same way that you can get a low-frequency energy build up if you don't roll the LF off on each track. Can't comment on 5.1, I'm just a plain ol' stereo broadcast man! |
#39
What were you listening to your bounced 5.1 mix on? Did you just re-import the bounced files into a Pro Tools session to listen, or did you encode them and listen to the mix on another format or system? If you encoded them, you should be aware that many AC3/DTS encoders' default settings are set to encode the surround channels 3db down, which would explain some of what you're hearing. If you're not playing the bounced mix back inside Pro Tools, whatever player or system you're using to play back the mix should be checked to make sure it's not set with the surround channels at the -3db default. |
Bouncing tracks quality loss. | Kemo3ce | Pro Tools M-Powered (Mac) | 14 | 10-03-2010 02:41 PM |
Loss of audio quality in editing Mastered Tracks in Pro-Tools? | allnightmusicman | General Discussion | 17 | 04-29-2010 10:10 PM |
Delay and loss of sound quality? Any help? | ablair3311 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 02-16-2010 03:15 PM |
Problem with sound quality after bouncing to disk | RogerC | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 01-26-2007 04:17 PM |
How to improve audio quality when bouncing tracks | krhaarmeyer | Tips & Tricks | 1 | 12-31-2000 12:37 AM |
