Re: MOBOX 3 PRO Breakout Cable
Ok the Monster Cables came as did the the MBOX3 Pro ...
I have a problem. The SPDIF Cables fit fine into the 11R which has an RCA output jack, the MBOX 3's breakout connector has two female connections, however they are real small like the size of a pin. I think they are called TOSLINK connections. Do they make connectors to convert these RCA Connections like the one on the 11R to the connection on breakout cable? Are there cables with both kinds of jacks? I have never used these connections before so I kind of lost on this. It looks like a cable tv wire connection Thanks in advance... SBS |
Can you post a photo of the connectors?
Yeah Man I messed up.... You are right.... I misread the wording on the plastic. It is hard to read.
My Bad I figured it out when I disconnected it to take the picture... Thanks again for all of your help SBS |
Need Breakout Cable for MboxPro 3 | nhmorgan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-09-2013 12:36 PM |
Mbox Pro 3 Breakout Cable | nhmorgan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-09-2013 11:33 AM |
Need replacement breakout cable!!! | kornrox593 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 11-11-2012 11:30 AM |
Breakout Cable | gerax | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-06-2001 06:52 AM |
how long is the pci to breakout cable? | theom | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 01-23-2001 06:57 AM |
