LFE channel panning?
I recently completed a 5.1 mix using bass management in Protools and I'm confused about the settings for the panner of the LFE. When I solo it, there's duplicate audio from the other channels, not just low end info and it's being reproduced on the other speakers. Shouldn't the audio for the LFE be isolated on the subwoofer? How do I set the panner to accomplish this? The crossover is set for 80HZ and no filter.
Thanks, Wrick |
Re: LFE channel panning?
What are you using for bass management? Bass management will do precisely that: catch low frequency information that the monitors of the main channels can't reproduce and divert them to the subwoofer (based on the idea that low-frequencies are non-localizable).
Are you soloing on the surround controller? If so, what you're hearing should be right. If you're soloing in ProTools and finding that you hear full-range sound on the LFE, you should note that the LFE send in each track's panner does not filter the sound to the LFE bandwidth, and some monitoring setups will not do it either (DMU in Line-in, for example). You should have an LFE master fader with an EQ3 1-band in Highpass@80Hz and 24dB slope inserted. |
Thanks for your response, Tigas. Yes when I solo the LFE with the JBL controller, the audio is correct. What concerns me is when I do a bounce, high and mid frequency info shows up on the LFE bounced channel. Also how do I prevent the LFE audio from showing up on the rest of the speakers?
As for LFE audio on the other channels, I'm not sure what you mean. |
I'm using the JBL 4328s with a JBL subwoofer. It comes with monitor control software including bass management. When I calibrated my control room, I did a calibration with and without bass management so I can selectively mix. Should I do a "cinema mix" without bass management and a "home theater mix" with bass management for home use?
What I mean about "other speakers" is when I re-import the 5.1 bounced tracks including LFE, back into a Protools session, that channel has a surround panner on it which sends the LFE audio wherever it's panned. I don't know how to defeat the channel panning so it goes only to the sub. I hope that's clear and I appreciate all the responses. |
You have to route that track directly to the LFE hardware output.
IHTH. Rob Burrell aka mixboy
http://www.robburrell.com PTHD Ultimate/Eucon (latest betas) / Mac Studio Ultra 128GB RAM / Aja T-Tap / Sonnet M.2 4x4 PCIe 8TB / Focusrite 16Line / MTRX Studio / UAD Octo / 32 channel S1 & Dock (5) 2019 Fire HD 10 / Dolby Atmos 9.1.4 /Mastering Suite / 13.0 Sony 360RA |
MC Mix-Stereo channel right side panning | priorytools | Artist Series | 3 | 08-29-2012 09:54 AM |
Strange CoreAudio issue - right channel information getting into left channel | -JK- | Pro Tools 9 | 5 | 01-10-2011 08:42 AM |
Multi-channel plugin default 'channel view'? | Floydio | Tips & Tricks | 1 | 11-26-2010 10:47 AM |
Selecting a Channel on Icon does not select channel in ProTools | teacherman | ICON & C|24 | 2 | 06-07-2010 11:59 AM |
How to Copy Plugin Insert From a Channel to other channel | Amr Mahmoud | ICON & C|24 | 8 | 11-12-2008 04:15 PM |
