Understanding System Usage
Does any one know where there is better information regarding HD system usage? How does plugin sharing work? Why do we have surroundmixer and stereomixer and how much power of our hd cards do these use? Whats the difference between voices allocated and time slots used?
Re: Understanding System Usage
These are good questions. I wish there was more info readily available. Page 57 of the PT reference guide talks about System Usage, Time Slots, etc. It's not the most detailed part of the guide. I can tell you that depending on sample rate, track count, RTAS plugs on Auxes (which takes voices), bussing within the session, automation, and voice count per DSP, the HD cards can change with the amount of power per session. If, at 96k, on an HD3 I run a session at 5 DSP's at 80 voices, and have 60-70 tracks, with bussing and HW outputs to headphone systems, my default template plugs (Revibe/TL Space/Echo Farm/H-Delay/Digi Pitch plug TDM on Aux returns) and 6-8 Aux returns for drums, keys, bass, guitars, vocals, percussion, etc, I can chew up a lot of the HD cards' processing with just that. I'll run TDM plugs on Auxes and RTAS plugs on individual tracks after they've been recorded (and do a little TDM->RTAS dance in the process). When I record at 48k, I have a LOT more DSP room, card/chip-wise. I cant help but feel that the dance is worth it, though. 88.2 and 96k is where I've been moving with Mac Pro's and RTAS plugs like SSL and CLA and the Glue. As always, depending on your card count, session needs, and sample rate, your mileage will definitely vary.
... but does it help the chorus? |
Understanding CPU Usage | ado811 | Pro Tools 11 | 1 | 11-28-2013 11:56 PM |
How come my system usage just keeps going up? | sb_stefan | Pro Tools 10 | 10 | 02-25-2013 09:37 AM |
Good System Usage/RTAS settings for Quad Core system | Mental Clarity | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 12-19-2008 03:09 PM |
Help understanding CPU Usage, RAM, Disk Usage... | Bezo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 02-03-2006 07:41 PM |
HTDM not showing CPU usage in the system usage | Brandonx1 | Pro Tools TDM Systems (Win) | 3 | 12-19-2004 09:45 AM |
