Re: Lets ALL chip in and buy and second HARD DRIVE for digi, so they can...
I've taken a look at that site and the optimizations - I'd be curious what you're seeing as far as actual performance gains. I've used the method of putting data on a separate drive (Mail, iTunes, photos, etc) for years and, honestly, it's not THAT much of a performance increase. How often are you going to have data access contention between Mail, iTunes, iPhoto, etc. and your applications? Also, there's an easier way to move your Home folder (including Mail data) to another drive - go to System Preferences>Accounts and click the lock, enter your password, then right-click on the account listed in the left hand panel and choose 'Advanced Options' - you can then choose a new folder for your Home. |
I think he's saying the performance gains are in using an SSD, which isn't large enough for all of the data contained in the home folder. It makes sense to me. I myself am waiting for larger SSD to become available so there's no need for that work around.
Just like it was stated as a new feature in Leopard 10.5.
2016 MacBook Pro Retina | 16GB RAM | 1TB SSD | OS X Latest - PTHD 12 Latest | 4K LG Thunderbolt Display | Logic Pro 10 |
What happens if you change your steps to the following? 1 - Install Leopard 2 - In system preferences, right click the admin account and choose advanced 3 - Assign the HOME directory to a DIFFERENT HARD DRIVE (Cost for 100GIG = $40,00 4 - Reboot 5 - Delete the OLD home folder I have used the advanced settings to change UIDs, and I have found that if you do not restart immediately after that funky things happen when creating additional user accounts. Perhaps deleting the old home folder before rebooting is contributing to the problem.
Here: http://www.avid.com/us/pressroom/Sec...9-Results.aspx |
#16
And I dont know about your interfaces and Software etc. But MINE STILL says digidesign and as long as they do I am going to refer to them as digidesign. I dont own a single thing with an AVID logo on it. (I think) Quote:
a new home folder. Goes without saying that I deleted that folder after the reboot. Sorry for the confusion. Quote:
Thanks though. I'll try the Log thing next time.
#17
So, I tried AGAIN and I think I found a problem. A problem with the installer that is.
If the PT Dock Icon (which I have moved from its original location) to the left of the dock rather than the right side, the installer will halt (according to the install log with when attempting to remove the dock icon with the following line Code:
Sep 25 18:25:24 ComputerName installd[13920]: ./preflight: Use of uninitialized value $text in pattern match (m//) at /Volumes/Hard Drive/MyHome/Desktop/Install Pro Tools HD Updater.mpkg/Contents/Packages/Application Files.pkg/Contents/Resources/remove_icon_from_dock.pl line 80, <DOCKPREFS> line 46. Code:
Sep 25 18:25:24 ComputerName installd[13920]: *** process 13920 exceeded 500 log message per second limit - remaining messages this second discarded *** OK. So I tried to remove the PT Dock Icon after installing PT 8.0 all over again(From a different account, before running the update from my MOVED account again. This time the installer did NOT halt at the dock thing but something very disturbing happened. In the end of installation I got a dialog that "You have chosen to install material which are located on the updater DVD, please insert that" WTF... I dont have ANY updater DVD what so ever. So, as I tried to FORCE QUIT the installer nothing happened. In fact I could NOT open ANY apps or finder windows. All I could do was to hold the Mac power button and jump start the CPU. Now, NO BOOT was happening. So I booted from a different drive and found out that I wasnt able to access(Finder) the hard drive where I had tried to install protools. So I opened the Terminal and had to log in as SUDO to view the drive. The PT installer had the set the permissions ALL WRONG. So I had to run a CHMOD 777 on the drive to able to boot from it again. After booting from that drive I repaired my disk permission which normally takes 2 minutes. This time it took 4 hours. And it was ALL the digi stuff which had wrong permissions. According to the details in the disk utility window. Regardless whether you believe me or NOT Mr. DTS... Your installer has a MAJOR problem which I can RECREATE every time. Just install OS X Leopard or Snow Leopard and assign the home folder to ANY other physical hard disk than the OS itself. Then in SYS PREF assign the home folder as well, reboot and try installing PT. In all honesty, I am seriously disappointed that you have not fixed this given the fact that I have been reporting this since early Leopard Days.
Problems with my second hard drive and my digi 001 | Elfnogg | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-12-2008 10:37 AM |
Digi 002 cause hard drive problem? | bighaircarey | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-30-2004 04:40 PM |
Hard Drive Question - Digi-001 | souelle | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-12-2003 08:34 PM |
Digi Hard drive question | michael verdes | General Discussion | 3 | 01-15-2001 10:03 AM |
Lets get the Hard Disk facts right | DJ Burt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 10-18-2000 09:22 PM |
