I'll check my exact DAE buffer sizes I'm using. |
Also, playback buffer is at 1500ms(Level 2) I've gone from 1-3
Did I miss something or did you mention if the drives you are using for recording or external or internal. If you haven't tried it, use external drives, making sure journaling is enabled, also make sure that they are in read mode (command I-for get info) and make sure your permissions, databases, blah blah ...are trashed. ALso, are you using other applications while trying to track? That's usually a no no.
Again I am just gessing that you are trying to record on yout internal drives. It can be sone but the messages you are receiveinf seem to point the fact that your system drive is working pretty hard. Ad an 80 track session to that and KA-BOOM! |
Well, they're all internal however the system drive, samples drive, and drive I record to are all separate thus leaving the system drive free to only run pro tools while I'm recording.
Re: DAE - 9073 On A Fairly Powerful System
I just had this issue and resolved it by switching firewire enclosures. Seems like the FW 800 port on the case I was using is NG. Might be your problem too...
Andy Snavley |
#16
Yea, I'm only using internal hard drives. All 7200 RPM SATA internal drives @ far less than 50% capacity. I have 4 internal, one for the system/pro tools app, one for recording to, one for streaming samples. Should be far sufficient.
#17
Are you using internal drives that also have your application on it? Don't do that. Also, get the application that is listed at the top of this forum and run iton all you syste,. It deletes databases as mentioned before and other prefs, etc., which could be messing you up. Also, only have the drives running (external) that you are using for your particular session. You can easily remount and dismount with a (command :-colon) and it will show your workspace nad you can go up to the upper left hand corner of the window and choose what drives to unmount and remount. Also, are you doing a round robin disk allocation? If you are doing a lot of work then it might be the way for you. Last 2 cents is to make sure your drives are compatible, usually the same type, 7200 RPM minimum and have at it. You may have a corrupted application too, so you may need to uninstall and reinstall Pro Tools. Best of luck to you! Hope some of this helps!!! |
#18
http://www.digidesign.com/index.cfm?...5&itemid=23132
IDE/ATA & SATA Hard Drives SATA Hard Drives Internal SATA drives are qualified for up to 32 tracks, 24 bit, 44.1/48 kHz with Pro Tools|HD systems on Power Mac G5 models. |
#19
I would point my finger at that being the problem. While you may get more than what we qualify, anything over 40 or so tracks starts to get into that questionable area where, truly, the drive just can't keep up. Try splitting the tracks between a couple drives and see if that helps. |
#20
If I'm going to continue to use the internal drives how can I separate the tracks to 2 drives instead of 1? Thanks |
Recurring PT rig crashes on powerful Mac Pro system; Magma Chassis the problem? | avonkorff | Pro Tools TDM Systems (Mac) | 7 | 08-15-2012 11:16 AM |
Ways to make LE system powerful - PCI cards etc? | VanGough | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 10-25-2005 01:00 AM |
Mix System VS Powerful PTLE System | muspro | Pro Tools TDM Systems (Mac) | 43 | 12-19-2002 09:06 AM |
Mix System VS Powerful PTLE System | muspro | Pro Tools TDM Systems (Mac) | 3 | 12-02-2002 04:31 AM |
PLANNING TO BUY A POWERFUL PRO TOOLS SYSTEM, PLEASE TELL ME WHAT I NEED FOR MY STUDIO | PCVPCV | Pro Tools TDM Systems (Mac) | 2 | 08-24-2001 04:56 PM |
