Go Back   Avid Pro Audio Community > Announcements > Technical Alerts
Old 01-28-2008, 11:52 PM
Avid's Avatar
Avid Avid is offline
Administrator
Default Pro Tools 7.3.1cs6 Updates for HD, LE, M-Powered Systems
Pro Tools HD, LE, and M-Powered v7.3.1cs6 updates are available for download from the Pro Tools CS Updates page:
www.digidesign.com/support/csupdates
(under Quick Links in the Support section)
Pro Tools HD 7.3.1cs6 for Mac OS X and Windows XP both include the following fixes:
Fixed: On D-Control and D-Command, the Touch Command Would Sometimes Not Engage When Quickly Grabbing a Fader (Item #87718)
  • The fader would "push back" and no automation would be written
Fixed: Pro Tools quits unexpectedly when moving a plug-in window while closing it from a control surface (Item #99442)
  • If a plug-in window was closed from a control surface while the plug-in window was being dragged across the screen, Pro Tools would quit unexpectedly.
Fixed: Opening a Session with an RTAS Version of Dynamics III Could Result in a Burst of Noise (Item #99562)
  • This problem was intermittent, and would not occur when using TDM versions of Dynamics III
Fixed: Surround Pan Automation is not Updating Properly in Loop Playback (Item # 85802)
  • The pan positions are correct on the first play of the selection, but can be incorrect on subsequent plays
  • Please note that there is still an outstanding issue where Surround Pan automation may stick on a particular output. Digidesign is currently working on a solution.
Pro Tools LE and M-Powered 7.3.1cs6 for Mac OS X and Windows XP all include the following fixes:
Individual Download Pages:
www.digidesign.com/index.cfm?&navid=54&itemid=29366
Pro Tools HD 7.3.1cs6 for Windows XP
www.digidesign.com/index.cfm?&navid=54&itemid=29367
Pro Tools LE 7.3.1cs6 for Mac OS X
www.digidesign.com/index.cfm?&navid=54&itemid=29369
Pro Tools LE 7.3.1cs6 for Windows XP
www.digidesign.com/index.cfm?&navid=54&itemid=29370
Pro Tools M-Powered 7.3.1cs6 for Mac OS X
www.digidesign.com/index.cfm?&navid=54&itemid=29371
Pro Tools M-Powered 7.3.1cs6 for Windows XP
www.digidesign.com/index.cfm?&navid=54&itemid=29372
Administrator
HTML code is On
Pro Tools 8.0.4 Updates for HD, LE, and M-Powered Systems Avid Technical Alerts 0 07-07-2010 01:34 PM
Pro Tools LE 7.1cs6 Updates Avid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-31-2006 04:34 PM
Pro Tools 5.3.1cs6 for HD Systems with SYNC I/O Avid Post - Surround - Video 0 03-22-2003 12:25 AM
Pro Tools 5.3.1cs6 for HD Systems with SYNC I/O Avid Pro Tools TDM Systems (Mac) 0 03-22-2003 12:24 AM
Pro Tools 5.3.1cs6 for HD Systems with SYNC I/O Avid General 0 03-21-2003 10:06 PM
