Go Back   Avid Pro Audio Community > Announcements > Technical Alerts
Old 12-21-2007, 01:52 AM
Avid's Avatar
Avid Avid is offline
Administrator
Default Pro Tools 7.4cs2 Updates for all 7.4 Systems
Pro Tools 7.4cs2 updates for all Pro Tools 7.4 systems are vailable for download from the Pro Tools CS Updates page:
www.digidesign.com/support/csupdates
And related support sections for Pro Tools 7.4 software and hardware.
Previous installation of Pro Tools 7.4 required to use these updates:In addition to previous items from Pro Tools 7.4cs1, the following fixes are included in Pro Tools 7.4cs2:
All Pro Tools HD, LE, M-Powered (Mac and Windows)
Fixed: Track Color Coding Saturation Was Not Adjustable (Item #94474)
  • Functionality is now the same as in Pro Tools 7.3.x
Fixed: Opening a Session with an RTAS Version of Dynamics III Could Result in a Burst of Noise (Item #99562)
  • This problem was intermittent, and would not occur when using TDM versions of Dynamics III
Fixed: Errors Resulting From Importing Certain Files Using Soundminer (Item #100028)
  • File names using an ellipsis (...) would cause the error, "Unable to create a new audio file on drive "xxx" for track "xxx" because I/O error (-36).
Fixed: Quantizing Grouped Elastic Audio Tracks Produces Some Inaccurate Transient Placement (Item #100013)
  • Transients could be placed either before or after grid lines
Fixed: User Can Only Promote the Confidence of an Event Marker by Moving it (Item #100378)
  • Clicking on any Event marker will now raise its internal confidence rating to 100%, thus preventing the marker from being removed when the Event Sensitivity setting is lowered within the Elastic Properties window
Fixed: Using Render or Commit With "Rhythmic" Algorithm Can Produce Artifacts at End of Files (Item #100420)
  • This would usually occur when using extreme amounts of stretching
Fixed: Elastic Time Warp Markers Could Move After Quantizing (Item #100423)
  • Quantizing a selected area could cause markers outside that selection to move
Pro Tools HD and LE Only (Mac & Windows XP)
Fixed: QuickTime Movies Would Cease to Play out Avid Video Peripherals After File Import (Item #100299)
  • This would occur after importing audio files from the Workspace Browser
Pro Tools HD Only (Mac & Windows XP)
Fixed: Time Code Chasing Not Possible After Time Code Reaches ~ 11 hours, 25 minutes, regardless of session start time (Item #99605)
  • This would occur with a session start time anywhere between 01 to 11 hours
Pro Tools HD, LE, M-Powered (Windows Only)
Fixed: RTAS Processor Selection in Playback Engine Dialog Was Greyed Out With Multi-Processor AMD-based Computers (Item #99545)
  • Note that this condition should only occur when HyperThreading is enabled on Intel-based computers
Fixed: Pro Tools May Crash While Setting Up MIDI When Administrator Account Name Contains a Non-English OS and/or a Non-ASCII Character (Item #100142)
  • Known to have occurred with Norwegian, Czech, Japanese and Korean Operating Systems
Administrator
HTML code is On
Pro Tools 8.0.4cs2 Updates for Mac and Windows Avid Technical Alerts 0 10-19-2010 01:56 AM
Pro Tools 7.4cs4 Updates for all 7.4 Systems Avid Technical Alerts 0 04-24-2008 12:41 AM
Pro Tools 7.4cs2 Updates for all 7.4 Systems Avid Post - Surround - Video 0 12-21-2007 02:59 AM
Pro Tools 7.3.1cs1 Updates for All 7.3.x Systems Avid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-12-2007 10:57 PM
Pro Tools 7.3.1cs1 Updates for All 7.3.x Systems Avid Technical Alerts 0 02-12-2007 10:50 PM
