Old 10-24-2010, 03:27 PM
hyperballad400 hyperballad400 is offline
Unhappy WAV file won't open in Pro Tools - reporter on deadline!
Hi there,
I'm a reporter for NPR (on deadline!) and I have used, I believed, the same configuration every time I have done reporting and this has never previously happened. I have an HHB Flash Mic, I pull the files off, and import into Pro Tools. This time, I believe a setting was changed on the mic and the files will not import. These new files do not open in iTunes -- however, they do open in Quicktime.
Older files that I recorded with the same mic are importing just fine. I took a look at the settings of the 2 files, and here are the differences:
New, non-opening files:
Bit rate: 160 kbps
Channels: 1 (mono)
Audio Sample Rate: 44 kHz
Old, functioning files:
Bit rate: 705 kbps
Audio sample size: 16 bit
Channels: 1 (mono)
Audio Format: PCM
Note that 2 of the attributes -- audio format and audio sample size -- were not given at all in the new files.
Any help is greatly, greatly appreciated.
Many thanks -
Old 10-24-2010, 03:40 PM
jeffro's Avatar
jeffro jeffro is offline
Post Re: WAV file won't open in Pro Tools - reporter on deadline!
Judging by the recording times listed here, it sounds like you were set to Linear PCM before but switched to MPEG1 Layer 2 at some point.
Maybe their software can convert the files, otherwise, if you say they will open/play in QuickTime you could possibly convert them to AIFF or WAVE using QuickTime Pro.
linkedin
Old 10-24-2010, 03:52 PM
cubivore cubivore is offline
Default Re: WAV file won't open in Pro Tools - reporter on deadline!
also the 'movie info' or clip inspector in QT might reveal the file attributes. i always find this useful for finding out framerates and other info about video files.
Old 10-24-2010, 04:23 PM
Kirby B. Kirby B. is offline
Not that knowledgeable in this domain, but you said you were on a deadline. QT Pro will let you export the files, I think, like JC of Avid said. best of luck and go, NPR!
Old 10-24-2010, 06:05 PM
thank you all for your input. brilliant move to actually take a look at the mic recording times -- i have a hunch that may be it. in a pinch, i have a music engineer friend who has some fancy program for saving the files.
thank you again, and if anyone else comes along the thread and has other thoughts, they are also very appreciated.
Old 10-25-2010, 04:22 PM
FYI...
Running the files through Quicktime Pro and exporting them there worked... when NONE of my engineer friend's fancy software could. Thanks all again.
Old 10-25-2010, 04:52 PM
slickrick slickrick is offline
Audition is a good side-app to have in these cases.
Sometimes those flashmics, in various users' hands and locations, adopt some pretty unique settings!
Pro Tools 10 won't open session file (Created on a newer version) sjafarzadeh Pro Tools 10 8 06-14-2023 11:24 AM
Pro Tools M Powered Can't Open File BRakestraw Pro Tools M-Powered (Mac) 0 12-01-2009 07:42 AM
Cannot open Pro Tools session file ephraim_malsawma Pro Tools M-Powered (Win) 3 05-09-2009 01:58 AM
Pro Tools file crashed on open. Mack Damon Pro Tools TDM Systems (Mac) 3 01-08-2005 10:51 AM
How do I open a Digital Performer file in Pro Tools 5.0? jeffjuliano Pro Tools TDM Systems (Mac) 2 04-06-2000 07:21 AM
