Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools SE and Essential (Win)
Old 07-30-2010, 09:26 PM
Yonn Yonn is offline
Default pro tools vocal studio problem
i have the pro tools vocal studio and after i open my session and import the beat and record the song i bounce it to disc but when im done with the song it comes out in bad quality it's very low and not clear
Old 07-30-2010, 10:13 PM
mikevarela mikevarela is offline
Default Re: pro tools vocal studio problem
If it sounds fine when you playback from pro tools, then it's your export. when you export to disc you can choose a few options
You need to check that your outputs are set at analog 1/2
that you select WAV and stereo or mono (you decide)
and that you select the audio specs you need, like 44.1/24bit.
If it still sounds like crap, then maybe you have plugins on the tracks that are affecting the audio, or the volume automation is low and it's affecting the bounce.
If that's not the issue, then your playback environment (cd player) is bad, or your recording just sounds bad in the first place.
NuanceTone.com
Old 07-31-2010, 07:45 PM
thanks for the tip but i dnt export it i bunce to disk and i set it on output 1-2 stero,wav,stero interleaved bit depth 16 and 44.1 for the rate and i dont know how to master or anyting so i have no plug ins i just import a beat rap in 1 audio and bounce it to disk is there anyway you can help me with this
Old 08-01-2010, 11:47 AM
Default mastering help
im new to pro tools and knw nothing about stacking and editing vocals or mastering i just rap on top of the beat can sum 1 send me an emial that likes to master and is good at mastering to do a couple of rap tracks i made
Old 08-01-2010, 11:56 AM
Gonk Gonk is offline
Default Re: Sound Problem
Practice is what you need to do, I'm assuming your using M-Powered Essential? not sure what plug in's come with that but I'm sure it must have a compressor, Reverb or delay those 3 will get you going, though I wouldnt advise using reverb and delay together on vocals (unless your after that kind of texture)
Try using the mic differently, are you too close to it, too far away from it when recording? once you find out how to use the mic half of your problems might be solved.
Check out some videos on youtube or go to the AIRusers blog, some really handy videos up on that site too.
Good luck!!
"Are you sure what side of the glass you are on?"
www.facebook.com/thereapersofficial
Old 08-01-2010, 12:03 PM
justus1900 justus1900 is offline
Default Re: mastering help
Man, you might want to read up on Mixing and Mastering. Songs need to be Mixed before you can Master. Mastering is an Art in its self. Like I can Mix a song but I would never try or even consider trying to Master one of my songs I would leave that up to a Professional Mastering House. I would check out some of the Videos on the Air Users Blog www.airusersblog.com and videos on YouTube www.youtube.com on Mixing then start to think about what Mastering realy is.
Producer/Engineer/Musician
RIAA Platinum Sales Award: Lisa Stansfield "Affection"
Main:
Model: Dell 5750 Precision Workstation
OS: Windows 11 Pro 64bit
CPU:*Intel Core Processor i7-10750H (6 Core, 12MB Cache, 2.60 GHz to 5.00 GHz,
Memory:64GB, 2X32GB,DDR4 2933Mhz Non-ECC
OS M.2 512GB PCIe NVMe, Record Intel 1TB SSD, 2T SSD, 1TB SSD
Focusrite Scarlett 18i20 3rd Gen
AVID Pro Tools 2023.12
JBL LSR4328P 8"
JBL LSR310S 10 inch Powered Studio Subwoofer*
Yamaha HS50M Studio Monitors
Alesis Elevate 3 Studio Monitors
M-Audio Axiom 61 Midi Controller
Old 08-01-2010, 01:47 PM
thanks but i still wanna see hw a mastered song sounds so if anybody likes to master rap songs can u put ya emial and ill send you the track
Old 08-19-2010, 11:48 PM
FrankAtkins FrankAtkins is offline
Cool Re: mastering help
Send me the session file and ill see what i can do ok
Frank'a
[email protected]
Old 09-03-2010, 09:33 PM
eddiegreat eddiegreat is offline
I wish i can ATLEAST open mine. It wont let me and i dont know why. Something about my m-audio and software not turned on or plug in is so getting me mad
Old 12-28-2010, 06:47 PM
ThisNewRapper ThisNewRapper is offline
Hey, i Bought the Avid vocal studio, and I cant get the beat to import onto the pro tools. It comes up with the integer error divide by zero thing. can anyone help?
Avid Vocal Studio with Pro Tools 10? Jeff Forehead macOS 0 11-23-2012 11:48 AM
Pro Tools Vocal Studio ProTools24 Pro Tools M-Powered (Win) 0 02-13-2011 05:46 AM
pro tools vocal studio HELP lefftyguitar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 07-04-2010 07:38 AM
Pro Tools Vocal Studio sverkalo Pro Tools SE and Essential (Win) 11 04-22-2010 02:44 PM
Pro-Tools M-Powered Essential Vocal Studio gchillag Pro Tools SE and Essential (Win) 0 02-12-2010 11:53 PM
