Old 08-30-2006, 02:07 PM
temetrepo temetrepo is offline
Default DAE error -6086
a friend is having this problem with his mbox 2
he's a total noob in this recording stuff
i'm trying to help him out with this
i've looked around and haven't found an answer for this
he gets that error after playing or recording after like 20 seconds.
it tells him to increase the buffer
we did it, still the same message
i found a few posts with similar problems, i tried those suggestions and didn't work./
here's a summary of his systems specs
hope someone can help
thanks in advace
<font class="small">Code:<hr /><pre>
Operating System Microsoft Windows XP Media Center Edition 5.1.2600 (WinXP Retail)
Date 2006-08-30
Time 12:07
Summary
Computer:
Computer Type ACPI Multiprocessor PC
OS Service Pack Service Pack 2
Internet Explorer 6.0.2900.2180 (IE 6.0 SP2)
DirectX 4.09.00.0904 (DirectX 9.0c)
Computer Name
User Name
SMTP E-mail Address
Logon Domain
Date / Time 2006-08-30 / 12:07
Motherboard:
CPU Type Intel Pentium 4 550, 3400 MHz (17 x 200)
Motherboard Name Dell Dimension 8400
Motherboard Chipset Intel Alderwood i925X
System Memory 1024 MB (DDR2 SDRAM)
BIOS Type Phoenix (10/11/04)
Communication Port Communications Port (COM1)
Communication Port ECP Printer Port (LPT1)
Display:
Video Adapter RADEON X300 Series Secondary (128 MB)
Video Adapter RADEON X300 Series (128 MB)
3D Accelerator ATI Radeon X300 (RV370)
Multimedia:
Audio Adapter Creative SB Live! 24-bit Sound Card
Storage:
IDE Controller Intel(R) 82801FR SATA AHCI Controller
IDE Controller Standard Dual Channel PCI IDE Controller
SCSI/RAID Controller Virtual CloneDrive
Floppy Drive Floppy disk drive
Disk Drive HDS724040KLSA80 (400 GB, 7200 RPM, SATA)
Optical Drive _NEC DVD+-RW ND-3450A (DVD+R9:2.4x, DVD+RW:16x/4x, DVD-RW:8x/4x, DVD-ROM:16x, CD:48x/24x/48x DVD+RW/DVD-RW)
Optical Drive ELBY DVD-ROM SCSI CdRom Device (Virtual CD-ROM)
Optical Drive HL-DT-ST CD-RW GCE-8483B (48x/32x/48x CD-RW)
SMART Hard Disks Status Unknown
Partitions:
C: (NTFS) 376750 MB (347266 MB free)
Input:
Keyboard Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
Mouse PS/2 Compatible Mouse
Network:
Primary IP Address 192.168.1.64
Primary MAC Address 00-11-11-88-DF-58
Network Adapter Broadcom NetXtreme 57xx Gigabit Controller (192.168.1.64)
Modem Intel(R) 537EP V9x DF PCI Modem
Peripherals:
Printer Fax
Printer HP Officejet 6200 series fax
Printer hp psc 1300 series
USB1 Controller Intel 82801FB ICH6 - USB Universal Host Controller [B-1]
USB2 Controller Intel 82801FB ICH6 - Enhanced USB2 Controller [B-1]
USB Device Digidesign Mbox 2 Audio Driver
USB Device Digidesign Mbox 2 Firmware Updater
USB Device Digidesign Mbox 2 Midi Driver
USB Device USB Composite Device
USB Device USB iLok Driver
DMI:
DMI BIOS Vendor Dell Inc.
DMI BIOS Version A03
DMI System Manufacturer Dell Inc.
DMI System Product Dimension 8400
DMI System Version
DMI System Serial Number
DMI System UUID
DMI Motherboard Manufacturer Dell Inc.
DMI Motherboard Product 0J3492
DMI Motherboard Version
DMI Motherboard Serial Number ..
DMI Chassis Manufacturer Dell Inc.
DMI Chassis Version
DMI Chassis Serial Number
DMI Chassis Asset Tag
DMI Chassis Type Mini Tower
Computer Name
Type Class Computer Name
Computer Comment Logical
NetBIOS Name Logical
DNS Host Name Logical
DNS Domain Name Logical
Fully Qualified DNS Name Logical
NetBIOS Name Physical
DNS Host Name Physical
DNS Domain Name Physical
Fully Qualified DNS Name Physical
DMI
[ BIOS ]
BIOS Properties:
Vendor Dell Inc.
Version A03
Release Date 10/11/2004
Size 512 KB
Boot Devices Floppy Disk, Hard Disk, CD-ROM, LS-120
Capabilities Flash BIOS, Shadow BIOS, Selectable Boot, EDD, BBS
Supported Standards DMI, APM, ACPI, PnP
Expansion Capabilities PCI, USB
[ System ]
System Properties:
Serial Number
Universal Unique ID
Wake-Up Type Power Switch
[ Motherboard ]
Motherboard Properties:
Product 0J3492
Serial Number ..
[ Chassis ]
Chassis Properties:
Serial Number
[ Processors / Processor #1 ]
Processor Properties:
Manufacturer Intel
External Clock 800 MHz
Maximum Clock 4000 MHz
Current Clock 3400 MHz
Type Central Processor
Voltage 1.6 V
Status Enabled
Upgrade ZIF
Socket Designation Microprocessor
[ Caches / Cache #1 ]
Cache Properties:
Type Internal
Status Enabled
Operational Mode Write-Back
Maximum Size 16 KB
Installed Size 16 KB
Error Correction None
[ Caches / Cache #2 ]
Cache Properties:
Type Internal
Status Enabled
Operational Mode Varies with Memory Address
Maximum Size 1024 KB
Installed Size 1024 KB
Error Correction Single-bit ECC
[ Memory Devices / CHANNEL A DIMM 0 ]
Memory Device Properties:
Form Factor DIMM
Type SDRAM
Type Detail Synchronous
Size 512 MB
Speed 400 MHz
Total Width 64-bit
Data Width 64-bit
Device Locator CHANNEL A DIMM 0
[ Memory Devices / CHANNEL B DIMM 0 ]
Form Factor DIMM
Type SDRAM
Size 512 MB
Speed 400 MHz
Total Width 64-bit
Data Width 64-bit
Device Locator CHANNEL B DIMM 0
[ Memory Devices / CHANNEL A DIMM 1 ]
Form Factor DIMM
Type SDRAM
Speed 400 MHz
Total Width 64-bit
Data Width 64-bit
Device Locator CHANNEL A DIMM 1
[ Memory Devices / CHANNEL B DIMM 1 ]
Form Factor DIMM
Type SDRAM
Speed 400 MHz
Total Width 64-bit
Data Width 64-bit
Device Locator CHANNEL B DIMM 1
[ System Slots / PCI_1 ]
System Slot Properties:
Slot Designation PCI_1
Type PCI
Usage Empty
Data Bus Width 32-bit
Length Long
[ System Slots / PCI_2 ]
Slot Designation PCI_2
Type PCI
Usage In Use
Length Long
[ System Slots / PCI_3 ]
Slot Designation PCI_3
Type PCI
Usage In Use
Length Long
[ System Slots / PCI_E_1 ]
Slot Designation PCI_E_1
Type PCI-E x1
Usage Empty
Length Long
[ System Slots / PEG ]
Slot Designation PEG
Type PCI-E x1
Usage In Use
Length Long
[ Port Connectors / PARALLEL ]
Port Connector Properties:
Port Type Parallel Port PS/2
Internal Reference Designator PARALLEL
Internal Connector Type None
External Connector Type DB-25 pin female
[ Port Connectors / SERIAL1 ]
Port Type Serial Port 16550A Compatible
Internal Reference Designator SERIAL1
External Connector Type DB-9 pin male
[ Port Connectors / KYBD ]
Port Type Keyboard Port
Internal Reference Designator KYBD
External Connector Type PS/2
[ Port Connectors / MOUSE ]
Port Type Mouse Port
Internal Reference Designator MOUSE
[ Port Connectors / USB1 ]
Port Type USB
Internal Reference Designator USB1
External Connector Type USB
[ Port Connectors / USB2 ]
Port Type USB
Internal Reference Designator USB2
[ Port Connectors / USB3 ]
Port Type USB
Internal Reference Designator USB3
[ Port Connectors / USB4 ]
Port Type USB
Internal Reference Designator USB4
[ Port Connectors / USB5 ]
Port Type USB
Internal Reference Designator USB5
[ Port Connectors / USB6 ]
Port Type USB
Internal Reference Designator USB6
[ Port Connectors / USB7 ]
Port Type USB
Internal Reference Designator USB7
[ Port Connectors / USB8 ]
Port Type USB
Internal Reference Designator USB8
[ Port Connectors / ENET ]
Port Type Network Port
Internal Reference Designator ENET
External Connector Type RJ-45
[ Port Connectors / MIC ]
Port Type Audio Port
Internal Reference Designator MIC
External Connector Type Mini-jack (headphones)
[ Port Connectors / LINE-OUT ]
Internal Reference Designator LINE-OUT
[ Port Connectors / LINE-IN ]
Internal Reference Designator LINE-IN
[ Port Connectors / HP-OUT ]
Internal Reference Designator HP-OUT
[ On-Board Devices / AC'97 Audio Controller ]
On-Board Device Properties:
Description AC'97 Audio Controller
Type Sound
Overclock
CPU Properties:
CPU Alias Prescott
CPU Stepping D0
Engineering Sample No
CPUID CPU Name Intel(R) Pentium(R) 4 CPU 3.40GHz
CPUID Revision 00000F34h
CPU Speed:
CPU Clock 3389.49 MHz (original: 3400 MHz)
CPU Multiplier 17.0x
CPU FSB 199.38 MHz (original: 200 MHz)
Memory Bus 199.38 MHz
CPU Cache:
L1 Trace Cache 12K Instructions
L1 Data Cache 16 KB
L2 Cache 1 MB (On-Die, ECC, ATC, Full-Speed)
Motherboard ID <DMI>
Chipset Properties:
Memory Timings 3-3-3-8 (CL-RCD-RP-RAS)
SPD Memory Modules:
DIMM1: Samsung M3 78T6553BG0-CCC 512 MB DDR2-400 DDR2 SDRAM (5.0-3-3-8 @ 200 MHz) (4.0-3-3-8 @ 200 MHz) (3.0-3-3-8 @ 200 MHz)
DIMM3: Samsung M3 78T6553BG0-CCC 512 MB DDR2-400 DDR2 SDRAM (5.0-3-3-8 @ 200 MHz) (4.0-3-3-8 @ 200 MHz) (3.0-3-3-8 @ 200 MHz)
BIOS Properties:
System BIOS Date 10/11/04
Video BIOS Date 04/05/12
Graphics Processor Properties:
Video Adapter ATI Radeon X300 (RV370)
GPU Code Name RV370 (PCI Express x16 1002 / 5B60, Rev 00)
GPU Clock 324 MHz (original: 324 MHz)
Memory Clock 196 MHz (original: 196 MHz)
Power Management
Power Management Properties:
Current Power Source AC Line
Battery Status No Battery
Full Battery Lifetime Unknown
Remaining Battery Lifetime Unknown
CPU
CPU Properties:
CPU Alias Prescott
CPU Stepping D0
Instruction Set x86, MMX, SSE, SSE2, SSE3
Original Clock 3400 MHz
Min / Max CPU Multiplier 14x / 17x
L1 Data Cache 16 KB
Multi CPU:
Motherboard ID DELL Dim 8400
CPU #0 Intel(R) Pentium(R) 4 CPU 3.40GHz, 3391 MHz
CPU #1 Intel(R) Pentium(R) 4 CPU 3.40GHz, 3391 MHz
CPU Physical Info:
Package Type 775 Contact LGA
Package Size 3.75 cm x 3.75 cm
Transistors 125 million
Process Technology 7M, 90 nm, CMOS, Cu, Low-K Inter-Layer, High-K Gate, Strained Si
Die Size 112 mm2
Core Voltage 1.425 V
I/O Voltage 1.425 V
Typical Power 84 - 115 W (depending on clock speed)
Maximum Power 101 - 151 W (depending on clock speed)
CPU Manufacturer:
Company Name Intel Corporation
Product Information http://www.intel.com/products/browse/processor.htm
CPU Utilization:
CPU #1 / HTT Unit #1 100 %
CPU #1 / HTT Unit #2 50 %
CPUID
CPUID Properties:
CPUID Manufacturer GenuineIntel
IA Brand ID 00h (Unknown)
Platform ID 13h (Socket 775)
IA CPU Serial Number Unknown
Microcode Update Revision 13
HTT / CMP Units 2 / 1
Instruction Set:
64-bit x86 Extension (AMD64, EM64T) Not Supported
Alternate Instruction Set Not Supported
AMD 3DNow! Not Supported
AMD 3DNow! Professional Not Supported
AMD Enhanced 3DNow! Not Supported
AMD Extended MMX Not Supported
Cyrix Extended MMX Not Supported
IA-64 Not Supported
IA MMX Supported
IA SSE Supported
IA SSE 2 Supported
IA SSE 3 Supported
CLFLUSH Instruction Supported
CMPXCHG8B Instruction Supported
CMPXCHG16B Instruction Not Supported
Conditional Move Instruction Supported
FEMMS Instruction Not Supported
MONITOR / MWAIT Instruction Supported
RDTSCP Instruction Not Supported
SYSCALL / SYSRET Instruction Not Supported
SYSENTER / SYSEXIT Instruction Supported
Security Features:
Advanced Cryptography Engine (ACE) Not Supported
Data Execution Prevention (DEP, NX, EDB) Not Supported
Hardware Random Number Generator (RNG) Not Supported
Montgomery Multiplier & Hash Engine Not Supported
Processor Serial Number (PSN) Not Supported
Power Management Features:
Automatic Clock Control Supported
Enhanced Halt State (C1E) Not Supported
Enhanced SpeedStep Technology (EIST, ESS) Not Supported
Frequency ID Control Not Supported
LongRun Not Supported
LongRun Table Interface Not Supported
PowerSaver 1.0 Not Supported
PowerSaver 2.0 Not Supported
PowerSaver 3.0 Not Supported
Processor Duty Cycle Control Supported
Software Thermal Control Not Supported
Temperature Sensing Diode Not Supported
Thermal Monitor 1 Supported
Thermal Monitor 2 Not Supported
Thermal Monitoring Not Supported
Thermal Trip Not Supported
Voltage ID Control Not Supported
CPUID Features:
36-bit Page Size Extension Supported
CPL Qualified Debug Store Supported
Debug Trace Store Supported
Debugging Extension Supported
Fast Save & Restore Supported
Hyper-Threading Technology Supported
L1 Context ID Supported
Local APIC On Chip Supported
Machine-Check Architecture Supported
Machine-Check Exception Supported
Memory Type Range Registers Supported
Model Specific Registers Supported
Page Attribute Table Supported
Page Global Extension Supported
Pending Break Event Supported
Physical Address Extension Supported
Self-Snoop Supported
Time Stamp Counter Supported
Virtual Machine Extensions Not Supported
Virtual Mode Extension Supported
Motherboard
Front Side Bus Properties:
Bus Type Intel NetBurst
Bus Width 64-bit
Real Clock 200 MHz (QDR)
Effective Clock 800 MHz
Bandwidth 6400 MB/s
Memory Bus Properties:
Bus Type Dual DDR2 SDRAM
Bus Width 128-bit
Real Clock 200 MHz (DDR)
Effective Clock 400 MHz
Bandwidth 6400 MB/s
Chipset Bus Properties:
Bus Type Intel Direct Media Interface
Motherboard Manufacturer:
Company Name Dell Computer Corporation
Product Information http://www.dell.com
BIOS Download http://support.dell.com
Memory
Physical Memory:
Total 1022 MB
Used 395 MB
Free 626 MB
Utilization 39 %
Swap Space:
Total 2514 MB
Used 364 MB
Free 2150 MB
Utilization 14 %
Virtual Memory:
Total 3536 MB
Used 759 MB
Free 2777 MB
Utilization 21 %
Physical Address Extension (PAE):
Supported by Operating System Yes
Supported by CPU Yes
Active No
SPD
[ DIMM1: Samsung M3 78T6553BG0-CCC ]
Memory Module Properties:
Module Name Samsung M3 78T6553BG0-CCC
Serial Number 0202D5EAh
Module Size 512 MB (1 rows, 4 banks)
Module Type Unbuffered
Memory Type DDR2 SDRAM
Memory Speed DDR2-400 (200 MHz)
Module Width 64 bit
Module Voltage SSTL 1.8
Error Detection Method None
Refresh Rate Reduced (7.8 us)
Memory Timings:
@ 200 MHz 5.0-3-3-8 (CL-RCD-RP-RAS)
@ 200 MHz 4.0-3-3-8 (CL-RCD-RP-RAS)
@ 200 MHz 3.0-3-3-8 (CL-RCD-RP-RAS)
Memory Module Features:
Early RAS# Precharge Supported
Auto-Precharge Not Supported
Precharge All Not Supported
Write1/Read Burst Not Supported
Buffered Address/Control Inputs Not Supported
Registered Address/Control Inputs Not Supported
On-Card PLL (Clock) Not Supported
Buffered DQMB Inputs Not Supported
Registered DQMB Inputs Not Supported
Differential Clock Input Not Supported
Redundant Row Address Not Supported
Memory Module Manufacturer:
Company Name Samsung
Product Information http://www.samsung.com/Products/Semi...DRAM/index.htm
[ DIMM3: Samsung M3 78T6553BG0-CCC ]
Serial Number 0210D5F6h
Module Width 64 bit
Memory Timings:
Chipset
[ North Bridge: Intel Alderwood i925X ]
North Bridge Properties:
North Bridge Intel Alderwood i925X
Revision / Stepping 04 / B1
Package Type 1210 Pin FC-BGA
Core Voltage 1.5 V
In-Order Queue Depth 12
Memory Controller:
Type Dual Channel (128-bit)
Active Mode Dual Channel (128-bit)
Memory Timings:
CAS Latency (CL) 3T
RAS To CAS Delay (tRCD) 3T
RAS Precharge (tRP) 3T
RAS Active Time (tRAS) 8T
Error Correction:
ECC Supported, Disabled
ChipKill ECC Not Supported
ECC Scrubbing Not Supported
Memory Slots:
DRAM Slot #1 512 MB (DDR2 SDRAM)
DRAM Slot #2 512 MB (DDR2 SDRAM)
PCI Express Controller:
PCI-E x16 port #2 In Use @ x16 (ATI Radeon X300 (RV370) Video Adapter)
Chipset Manufacturer:
Product Information http://www.intel.com/products/browse/chipsets.htm
Driver Download http://support.intel.com/support/chipsets/index.htm
[ South Bridge: Intel 82801FR ICH6R ]
South Bridge Properties:
South Bridge Intel 82801FR ICH6R
Revision / Stepping D3 / B1
Package Type 609 Pin mBGA
Package Size 3.1 cm x 3.1 cm
Core Voltage 1.5 V
PCI-E x1 port #1 In Use @ x1 (Broadcom NetXtreme BCM5751 Gigabit Ethernet Controller)
PCI-E x1 port #2 Empty
BIOS
BIOS Properties:
BIOS Type Phoenix
BIOS Manufacturer:
Company Name Phoenix Technologies Ltd.
Product Information http://www.phoenix.com/en/products/default.htm
BIOS Upgrades http://www.esupport.com/biosagent/in...m?refererid=40
Problems & Suggestions:
Suggestion Are you looking for a BIOS Upgrade? Contact eSupport Today!
Operating System
Operating System Properties:
OS Name Microsoft Windows XP Media Center Edition
OS Code Name Whistler
OS Language English (United States)
OS Kernel Type Multiprocessor Free
OS Version 5.1.2600 (WinXP Retail)
OS Installation Date 12/11/2004
OS Root C:\WINDOWS
Originally Posted by JustinA
"Soon" as in we should be refreshing our browsers, or "soon" as in ADC coming to LE?
Old 08-30-2006, 02:17 PM
JMS40 JMS40 is offline
Default Re: DAE error -6086
The Mbox 2 is incompatable with both the Intel 925X chipset and XP Media Center Edition. (Chipset is likely the show-stopper here as some here have gotten along fine with XP MCE.)
See the Mbox 2 Compatibility Page.
And the specific Chipset document.
Old 08-30-2006, 03:52 PM
thx for the heads up bro
i didn't notice the chipset post
question
if he gets a pci usb card, will it work?
or will he still get the same prob.
i'll let him know the bad news
thx again bro
Old 08-30-2006, 04:06 PM
I don't think so. However, he might try an externaly powered USB hub. It's been written about as a solution in some cases. I have no first hand knowledge.
Good luck-
I didn't read the whole report but I couldn't see if he is recording to a physically different hard drive than the system drive. This is virtually a must.
Obsidian Dragon
Mac Studio M1Max - 64GB
Old 08-30-2006, 07:39 PM
yearding to the sam OS drive
i told him to get an xternal one
das the nest thing on his to buy list
ill let him know bout the Powered xternal hub
thx for the replies
Error -6086 urlazyd Pro Tools TDM Systems (Win) 0 07-21-2010 01:40 PM
6086 Error since 8.0 Ichmichmirmein 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 24 12-30-2008 11:45 PM
Error 6086 arnocekkert 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 02-21-2008 02:00 PM
Error -6086 Benjamin Golby 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-16-2006 09:56 AM
the -6086 error smithers 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-10-2005 07:15 PM
