  #31
Old 01-25-2016, 10:19 AM
Greeno Greeno is offline
Default Re: Avid Space is not true stereo :-(
Thanks for confirming Space is still broken.
Does anyone have any specifics regarding the bugs? It'd be great to know more details so that if the plugin is only partially broken, I can check my sessions with Space instantiated and assess the impact!
Obviously looking to move away from Space now (as it sounds like many others have already done sadly), but hoping to salvage my sessions which already use Space.
Many thanks,
  #32
Old 01-30-2016, 04:39 AM
CME CME is offline
Fwiw liquid sonics reverberate has been great. And the new version with fusion IR's is even better.
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier.
  #33
Old 08-23-2020, 06:55 AM
Firechild Firechild is offline
Any news on this?
Still only mono input even if using true stereo to stereo.
iMac Pro - HDX2 - Mojave - AVID HD I/O x7
  #34
Old 08-23-2020, 01:12 PM
Originally Posted by Firechild View Post
Any news on this?
Make sure you're using stereo to stereo ir's.
Jack
QAPLA!
  #35
Old 08-23-2020, 01:25 PM
Top Jimmy's Avatar
The last time an Avid dev worked on the code for Space, there were some routing issues that didn’t get worked out. Basically, stereo-stereo configuration is convolving both sides with both the left and right stereo impulse responses which is mixing them together when it shouldn’t.
James Cadwallader
  #36
Old 08-24-2020, 03:46 AM
That almost sounds like LiquidSonics Reverberate 2's true stereo mode.
Jack
QAPLA!
  #37
Old 08-30-2020, 09:39 PM
As someone mentioned. A good workaround is to use two mono to stereo instances and load mono Left to stereo and then mono right to stereo.
The Samplicity Bricasti library has that kind of files. No need for converting either, just load.
https://web.archive.org/web/20190201...lse-responses/
So you just set up a stereo send with two mono sub-paths.
HTML code is On
TL SPACE - what kind of impulses are needed for true stereo?? BasketCase Pro Tools TDM Systems (Mac) 1 08-19-2012 02:11 AM
Recipe to crash PT 9 = TL Space with True Stereo Impulses 25ghosts Pro Tools 9 4 12-01-2010 03:11 AM
TL Space - True Stereo montezuma 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 02-22-2010 07:39 AM
PT 8.0.3 & TL Space Latest Version --- True Stereo Madness 25ghosts Pro Tools TDM Systems (Mac) 1 02-11-2010 09:07 PM
TL Space True Stereo Routing Issue - HELP innenhofstudios Pro Tools TDM Systems (Mac) 2 02-18-2009 08:27 AM
