Old 06-04-2019, 10:30 AM
streamingtheatre streamingtheatre is offline
Default Eucon 19.5.1 is out now
Eucon 19.5.1 is out now...
Old 06-04-2019, 07:48 PM
MoPro's Avatar
MoPro MoPro is offline
Default Re: Eucon 19.5.1 is out now
You first!
Computer Asus P9X79 Deluxe | Intel i7 3930k | 32 Gig Ram | Intel 520 SSD's | 2T Caviar Black
Software Win 7 Ultimate (64bit) | Cubase Pro 9.5.41 (64bit) | WaveLab 9.5.25 (64bit) | HALion 6 (64bit)
Hardware RME FireFace's UFX / 800 | MOTU MTP AV USB | Avid Artist Series: Control, Mix, and Transport | EuControl ver. 18.3
Old 06-04-2019, 09:28 PM
BScout BScout is offline
19.5.1 fixes things that people on the forums were complaining about. It's a safe bet.
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3
Old 06-05-2019, 03:47 AM
"Navigating in the Pro Tools Edit window using the “p” or “;” keys could fail to maintain track Attention and/or window focus (GWSW-12433)"
I tried this but it only seems to work for plugin windows and the pan window. Sends however just close when you move to the next track.
F.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron
Old 06-05-2019, 09:43 AM
EddieJones's Avatar
F.
Correct, this is because send windows work differently, may not be there or maybe a different one.
Old 06-06-2019, 06:17 AM
Thanks, at the moment it closes even when it's the same slot sending to the same bus. Keeping it open would indeed help for example when you're trying to apply some reverb to 5 tracks on elements belonging to the same effect in a film session. In that case you'd have sends in slots 1-3 unified across a whole set of tracks for example.
Maybe the send can close if the send in a given slot on the next track is going to a different bus to signal it's a different effect you'd be sending to.
Thanks
Frank
Old 06-08-2019, 11:43 AM
noiseboyuk noiseboyuk is online now
What’s Fixed in EUCON 19.5.1
S6
• Some S6 M10 system licenses could fail after upgrading to v19.5 (GWSW-12430)
• VCA bus knobs could fail to update displayed values (PT-251990)
Requires Pro Tools 2019.6
All EuControl Devices (S3, Dock, Pro Tools | Control, and Artist Series) and EuControl Software
• EuControl: Soft Keys for Pro Tools could fail to import into v19.5 (GWSW-12432)
• On macOS Mojave, text such as application names could appear upside down (GWSW-12442)
• Pro Tools | Control could fail to accurately indicate workstation connection status when focused on a non-EUCON application
(GWSW-12441)
• Layouts could fail to be saved as expected (GWSW-12455)
• It was possible for windows to open and close (or not) in an undesirable fashion when using the Attention and Open Window settings added in v19.5. See Open Windows on Workstation Attention.
• S3 and Mix: OLEDs could fail to update (GWSW-12431)
• S3: Plug-in and Send windows could fail to close after navigating back to the top level Inserts or Sends view (GWSW-12456)
• Adding or deleting tracks in Cubase or Nuendo could appear to freeze and blank out surfaces (GWSW-12466)
• MackieControl could fail to load if auto-started by EUCON Preferences on macOS (GWSW-12443)
• An appset has been added for Calendar on macOS
All Systems:
• Show Momentary Fader Values could fail to show parameter values as it had in previous versions (GWSW-12427,
GWSW-12438)
To improve Momentary Fader Value display, new options have been added to support the Fader Value Timeout slider. See
Improved Momentary Fader Value Display.
• Navigating in the Pro Tools Edit window using the “p” or “;” keys could fail to maintain track Attention and/or window focus
(GWSW-12433)
• Functions not set to open windows could fail to close windows (GWSW-12453)
Requires PT 19.6
No word on any fix for Cubase.
Guy Rowland
www.guyrowland.co.uk
PT 2024 Ultimate; W11 Pro; Ryzen 9 7900; 64gb RAM; RME Babyface; UAD Quad Satellite USB; GTX 1050i
Macbook Air M2; 24gb RAM
Old 06-08-2019, 11:54 AM
EddieJones's Avatar
• Adding or deleting tracks in Cubase or Nuendo could appear to freeze and blank out surfaces (GWSW-12466) ?
Old 06-08-2019, 11:53 PM
ALSTUDIOS ALSTUDIOS is offline
Hi
Yes, confirm, that this problem has been resolved.
Cheers
ALSTUDIOS REGENSDORF SWITZERLAND
[email protected]
https://sites.google.com/site/alrecordingstudio/
1pc AVID Artist Control and 1pc Euphonix MC Mix
Win11 64Bit, Cubase Pro 12.0.52
Old 06-09-2019, 05:45 AM
I'm blind! Thanks folks, I'll give it a try here.
Guy Rowland
Eucon 3.2.2 installer error + firmware downwards compatible with eucon 3.1 deauditievedienst Artist Series 2 07-14-2021 09:33 AM
Updated to Eucon 3.6 and lost all my custom Eucon commands bassmagnetic Avid S1, S3, Dock and Control App 0 04-18-2017 10:09 AM
EuCon suddenly broken - Eucon client can not access the bonjour service noiseboyuk Artist Series 0 04-12-2016 12:34 PM
EUCON 2_6_1 eucon discovery cant find ip klaukholm System 5 2 10-22-2011 12:01 PM
