Command-8 connected to Digi002R HELP !
Hi, I know this is going to sound simple, but being new to this I need some direction. I had the mbox2 installed on my windows compuer with verison 7pt. Worked great. Then I moved up to the digi 002R. Worked evern better. Having so much fun, I purchased a near new Command 8. Now, am like a calf looing at a new gate. I don't have a clue how to connect the command-8 to the digi 002r and then to the computer. I have one M-Audio oxgen-8 midi controler also. The command-8 manual does not cover this in detail nor does the digi002r manual. I would greatly thank anyone who can walk me through these steps. Thank you again for you time, Jim
UPDATE: When I select surface under the midi out and in, PT sees the board and everything works, I think. The NEW problem now is I can't hear anythng out of the monitors! They are connected to the digi002r, but still nothing. I can hear the mix only through the headphone jack and only on the digi002r and not at all through the command 8. I am sure it's a matter of connections, but still don't know how to interface these two units. Thanks for you help, Jim
When I die, I want to go like my Grandpa did, quietly in his sleep and not like the screaming passenger on the back of his motorcycle! |
Re: Command-8 connected to Digi002R HELP !
You have to connect your monitor outputs on the 002R to the monitor inputs on the C/8. Then connect your monitors to the outputs on the C/8. If you can hear from the phones output on the 002R I don't see why the monitor output isn't working. Check all your connections again.
Intel I7 920 Asus P6T Digi 002R. Command/8 PTLE 7.1 MPT www.clearspotrecording.com |
Thank you for the advise. I followed your lead and everything works perfect now! Thanks again for your time!
Command 8 with Digi002R? together or not | TDub | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 11-25-2010 03:33 AM |
Command 8 and Digi002R completely standalone | majo72 | ProControl, Control|24, Command|8 | 2 | 09-24-2009 05:59 AM |
2 Computers + 1 Digi002R connected via FW Switch? | schpilkas | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-16-2009 12:32 AM |
Digi002R with command 8 connections no sounds ? | jimmyl | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 01-03-2006 07:29 PM |
Command 8 and Digi002R Monitoring | Hardmtl | ProControl, Control|24, Command|8 | 6 | 01-14-2005 06:29 PM |
