Go Back   Avid Pro Audio Community > Pro Mixing > Avid S1, S3, Dock and Control
Old 07-01-2020, 04:46 AM
SvenIsak SvenIsak is offline
Default Avid Control app does not connect
I can't get the Avid Control app for the iPad to work.
The iPad is connected to a working Wi-Fi network.
The app does NOT show up among the surfaces in the EuControl application on my Mac.
The "About" screen, in the "Settings" panel on the iPad app, shows "Not Connected". How do I get it to connect?
I haven't used the app in a while, but it used to work!
Old 07-03-2020, 06:39 AM
creativecontrol's Avatar
Default Re: Avid Control app does not connect
The first thing I would recommend verifying is that you a running a matched set of versions for EuControl as you are for the Avid Control app.
Jeff
Jeff Komar
Solutions Specialist, Pro Audio
S6 FAQ
Old 07-05-2020, 11:35 AM
It appears that you are correct, Jeff. To a point!
I Installed the latest version (20.6.1.3) of the EUCON software. Now, the Control app shows up in the EuControl Settings on the Surfaces tap.
Unfortunately, it ends there! The EUCON software just hangs up (with the beach-ball of death). I just have to force quit it. My Artist Control and Artist Mix are just a couple of thousand dollars worth of electronic garbage!
Reverting back to a previous version (19.12.1.23.106561) of the EUCON software got the control surfaces (and the EuControl Settings) working again. However, now I get an error message, telling me that the Control app and the version of EuControl is incompatible.
Avid really need to release a Mojave compatible version of the EuControl software!
Most Waves plugins cannot be set properly from Avid control surfaces / Avid Control? XJENSEN Avid S1, S3, Dock and Control 1 02-14-2020 06:22 AM
From Avid Connect Simon2065 Pro Tools 12 0 04-22-2017 04:53 PM
Connect an old 192 to Avid HD i/o? boomish69 Pro Tools 11 6 03-17-2016 11:41 AM
Control Surface For Protools 10 Mackie Pro Control or Avid Artist Control lberrios1962 Pro Tools 10 18 05-26-2012 12:51 AM
How Do you Connect The Control 24 to 4 192's? Ghieri ICON & C|24 2 04-30-2006 11:23 AM
