Old 09-18-2012, 09:39 AM
lancemcv's Avatar
lancemcv lancemcv is offline
Question Avid Says MT Lion and 2008 mac pro not supported??
I wish Avid would state why the older mac pro 2008 is not compatible with Mt Lion and I guess Pro tools 10.3. I currently have Pro Tools 10.2 running with MT 10.8.1
What is new about 10.3 anyway.... just thunderbolt compatibility or is there
more, I can't find any other info. I am not going to update as there is no need but just wondering if this is the end of the road for support of my mac pro.
Here is Avid's info below which I find a bit vague.
Pro Tools Version 10.3 is an officially qualified and recommended installer for:
Pro Tools systems on Mac OS X 10.6.7 - 10.8*
*Mac OS X 10.8 support for Nehalem (4,1) and higher Mac Pro computers
The last bit is what I would like more information on...
Apple states MT Lion is compatible with "Mac Pro (Early 2008 3,1 or newer)" so I don't get what Avid is stating here.
Anybody have insite to this? Maybe Avid just made a mistake of which macs pros are compatible with MT Lion.
Old 09-18-2012, 10:18 AM
Lincoln Mitchell Lincoln Mitchell is offline
Default Re: Avid Says MT Lion and 2008 mac pro not supported??
Dan? Care to enlighten this chap?
Lincoln Mitchell
Pro Tools | latest
Mac Mini Server | OSX | Current
16GB Ram | SSHD
Apogee Ensemble Thunderbolt
Old 09-18-2012, 10:27 AM
Default
This is beyond silly, c'mon Avid how about rewording the release notes to avoid these silly confusions and upset customers for just no reason (except poor/unclear writing style).
Old 09-18-2012, 10:40 AM
10.3 is compatible from 10.6.7 and up. Period.
Lincoln Mitchell
Pro Tools | latest
16GB Ram | SSHD
Old 09-18-2012, 11:18 AM
lancemcv's Avatar
Thanks for the clarification, I would like to see Avid correct this on there compatibility page. Are there any fixes aside from MT Lion and Thunderbolt being supported with PT 10.3?
I looked at the read me file that comes with the installer but it is just the what's new with PT10 read me file, it's same that came with earlier versions, there does not seem to be any other info on the update.
Guess I will just do a full system drive clone tonight and then install 10.3 and see how she runs.
I have been getting pops at the end of my recorded clips unless I set DC to short, then they go away. Hopefully this will be fixed with 10.3 as some other folks seem to have the issue, and no one seems to know what causes it.
Old 09-18-2012, 11:19 AM
Issues Resolved in Pro Tools 10.3 Display
Waveforms are now drawn correctly in the Fades dialog when the start or end points are moved in from the edges. (PTSW-157852)
Playback and Recording
A class of unexpected 9092, 9093, 9128, or 9129 errors no longer occurs. An error that caused the counters to incorrectly indicate a very high speed of playback or record no longer occurs. (PTSW-163794)
Input meters on HDX systems now properly indicate clipping. (PTSW-165661)
Scrubbing on tracks above 192 voices on HD Native no longer causes Pro Tools to quit unexpectedly. (PTSW-171347)
Destructive Punch
Magic ID error is no longer encountered when using Destructive Punch in certain situations. (PTSW-156797) Destructive Punch now works properly with interleaved audio files. (PTSW-163841)
Automatic Delay Compensation
Delay Compensation may now be enabled for plug-in sidechains in the Operation preferences. (HDX hardware-accelerated systems only).
Pro Tools 10.3 and Pro Tools HD 10.3 on Mac OS X 10.6.x, 10.7.x and 10.8.x — 9/6/12 4
Automation
Nudging automation selections now maintains automation shapes inside and outside the selection by inserting anchor breakpoints at the selection edges. (PTSW-170098, PTSW-170102)
Glide automation correctly glides between values in a selection. (PTSW-166746)
Automation data can be pasted correctly when Automation Follows Edit is disabled. (PTSW-164539)
Pasting automation selections no longer creates unexpected ramps. (PTSW-158837)
Trimming clips with automation no longer creates unexpected ramps. (PTSW-168444)
Automation trimming is now limited such that the lowest value can be trimmed up only to the maximum possible value, and the highest value can be trimmed down only to the minimum possible value. (PTSW-167044)
Spurious -9155 (automation too dense) errors have been resolved. (PTSW-158618)
Performance has been improved in Continuous Scroll mode when using the “All tracks in Volume view” key command Option + “-” (minus) (PTSW-163652)
Pro Tools no longer quits unexpectedly when coalescing volume automation to clip gain. (PTSW-164914) Clip gain positions are no longer affected by the padding amount in Compact Audio dialog. (PTSW-163745)
Editing
Nudging audio within a region no longer affects audio on undisplayed alternate playlists. (PTSW-138403)
Using the Object Grabber to duplicate one or more clips to a different location on the same track(s), either to the insertion point or by dragging, now correctly results in only the copied clips being object-selected, and not the originals. (PTSW-167253)
Elastic Audio Commit works correctly when there are tempo changes in the session. (PTSW-165797)
Plug-Ins and Processing
Audio sync issues when rendering clip gain on clips with crossfades have been resolved. (PTSW-170425)
The Right-Click menu is now available for making the input (sidechain) active or inactive. (PTSW-166221)
Key input (sidechain) menu text is now italicized when made inactive with the Control-Command key command. (PTSW-166219) Do To All and Do To Selected are now available for Key input menu active / inactive state.
Mod Delay III correctly recalls tempo sync settings on session open. (PTSW-165514)
Mod Delay III follows tempo changes correctly in Sync mode. (PTSW-165607)
Mod Delay III note value buttons work correctly in stereo link mode. (PTSW-166842)
Native Instruments Kontakt no longer causes Pro Tools menus to become grayed out. (PTSW-166474)
An error in “ViewsUOSWindow.MacCarbon.cpp Line 1817” no longer occurs with several third party plug-ins. (PTSW-168032)
System Usage Window
The CPU Usage meter now displays CPU cycles required for communication with the HD Native and HDX PCIe cards. The meter is more accurate than before with these systems.
Pro Tools 10.3 and Pro Tools HD 10.3 on Mac OS X 10.6.x, 10.7.x and 10.8.x — 9/6/12 5
MIDI
MIDI data selection is now correctly based on the displayed location of the data, which is dependent on the “Display Events as Modified by Real-Time Properties” preference. (PTSW-161895)
MIDI CC data now displays correctly when the “Display Events as Modified by Real-Time Properties” preference is changed. (PTSW-142253)
Selecting notes with the marquee in Notes or Velocity view, after having done so in a previously opened session, will no longer cause crashes. (PTSW-164990)
A new preference has been added on the MIDI pane under Delay for External Devices: Notes and Controllers. When enabled, Pro Tools applies Delay Compensation to MIDI notes and MIDI controller data. This is helpful when monitoring external MIDI devices outside of Pro Tools.
Control Surfaces
The handling of ICON-specific session data has been optimized to improve performance of the Save Session command. (PTSW-164767)
On ICON worksurfaces, the LFE channel is available in 5.1 mode on the touchscreen surround panner. (PTSW-136779)
On ICON worksurfaces, when using the EQ III AAX plug-in, the “Q” knob for LF and HF bands in the EQ section now adjusts Q in bell mode correctly. (PTSW-165549)
Video and Synchronization
All Satellite Link and Video Satellite systems now stop on the same location when rewound to the beginning of the session. (PTSW-161241)
Media Composer now stops in sync when Pro Tools is recording. (PTSW-161353)
Pro Tools stops sending timecode when a played selection ends. Devices receiving timecode stop correctly when Pro Tools stops. (PTSW-151199)
Locating from a 9-pin controller now reliably updates Pro Tools location. (PTSW-163261)
Spurious timecode values are not sent during certain transport command sequences. (PTSW-167405) When using BlackMagic video output, 1080p24 and 720p59 formats are now properly set. (PTSW-3099)
Lincoln Mitchell
Pro Tools | latest
16GB Ram | SSHD
Old 09-18-2012, 11:32 AM
lancemcv's Avatar
Thanks Lincoln I should have dug a bit deeper on the 10.3 update page. Just found the pdf. That's a lot of fixes...Thanks again.
Old 09-18-2012, 11:48 AM
no sweat.
Lincoln Mitchell
Pro Tools | latest
16GB Ram | SSHD
Old 09-18-2012, 04:26 PM
TimNielsen TimNielsen is offline
I'm convinced the issue mainly stems from a particular set of errors that many of us using a Harpertown 2008 Mac were and are having with an HD Native card. For many many many months Avid has been unable to squash the bug. It remains to this day. 10.3 didn't fix it.
So the cynic in me believes they just dropped support for the Harpertown because they can't make ProTools with with it, with an HD Native card. Now they have the out of saying 'well that's not a supported system'.
There should be no other reason they would do that.
By the way, 10.3 is working 100% fine on my Harpertown, now that I've changed from an HD Native and Omni to a MOTU 828 Firewire interface. Most stable system I've had in years.
Old 09-18-2012, 10:21 PM
Dj-Ike Dj-Ike is offline
Working fine for me too, except Kontakt 5.
Music is the Message
8 core 2008/ PT 10/ Mountion Lion /003 HELP malakiband 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-21-2013 04:01 PM
Mountain Lion / Mac Pro 3,1 (2008) audiofp macOS 5 11-10-2012 12:36 PM
Mac Pro 3,1 (2008) / Mountain Lion audiofp Pro Tools TDM Systems (Mac) 0 11-09-2012 09:27 AM
Warning: DD client is not supported on OS X 10.7 Lion cmarkle_aspera Aspera DigiDelivery 18 05-10-2012 12:57 PM
is 10 supported on lion? pinnacle macOS 6 10-23-2011 05:13 PM
