Issue with 8.0.3 and switching to other applications
I have found that since I have upgraded to 8.0.3, have difficulty switching to other applications while Pro Tools is playing back.
For example, when I loop a section of dialogue and then switch to FileMaker Pro (via Command + Tab) to create an ADR cue, I find that only about 40% of time will the FileMaker window surface above the quicktime video in Pro Tools. The other 60% of the time, the application will be switched but the FileMaker window remains behind the quicktime video. This is the same when switching to other applications and windows as well. Has anyone else experienced this? -Justin
Justin Walker |
Re: Issue with 8.0.3 and switching to other applications
Also, this only seems to happen when application windows are open behind the Pro Tools quicktime window, so the problem appears to be related to the quicktime window only.
Justin Walker |
Bump
Justin Walker |
not the first quicktime bug in 8.0.3, and digi have acknowledged. Check DIAFXMX's thread.
Switching between HD and LE plug in issue | MX582 | Pro Tools TDM Systems (Mac) | 2 | 03-11-2011 08:51 PM |
Using your DAW for other applications? | NoiseRoom | macOS | 3 | 12-09-2010 05:22 PM |
Switching from M-Powered PT 7.4 to LE 8.0 region placement issue | Gabe Lewis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 11-03-2009 10:09 AM |
Third party applications with PT 7.2 | Jsalam112 | Pro Tools TDM Systems (Mac) | 1 | 09-18-2006 03:24 PM |
6.7cs7 Audiosuite switching issue | Farmer Dave | Pro Tools TDM Systems (Mac) | 3 | 01-26-2005 10:14 AM |
