Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 12-05-2018, 02:33 PM
Default dynamic eq - range and compression ratio
Something I'm trying to wrap my head around ever since I got the demo of Fabfilter Pro Q3 and purchased Waves F6 - they both have range controls for reduction or expansion which I like. However my other 'dynamic eq' which is HOFA IQ-EQ doesn't have that control but does have a compression ratio control for the dynamics. Now I understand what the ratio control does for regular compression but what about in a dynamic eq usage? Doesn't make sense to me.
Is there some way to relate the functions to each other? Every time I think I have a handle on this the further I look at it I can't make the connection between the two methods with dynamic eq work. It may well be something simple but right now it's driving me to drink (thank you Mr. Beam & Mr. Daniels)
Jack
QAPLA!
Old 12-05-2018, 03:14 PM
amagras amagras is offline
Default Re: dynamic eq - range and compression ratio
Range puts a limit to the amount of compression regardless of the position of the threshold, for example you can reduce the threshold until the signal surpasses it by 50db but if range is set to -20db the compressor won't reduce more than 20db. It is different from ratio in that it allows you to reach further down with threshold while having a limited amount of gain reduction. Cytomic The Glue has both which I find quite useful, it has helped me reach the lower dinamic layers of some particularly problematic mixes without overcompressing the whole thing
https://youtu.be/mHhk3go-3qg
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 12-05-2018, 03:19 PM
crizdee's Avatar
crizdee crizdee is offline
FF Pro Q and Sonnox Oxford dynamic EQ both have a dynamic range control, which is fundamentally the ratio, just doesn't have a ratio setting just a more or less, sets the target for the compression/expansion to reach. Just being a dynamic EQ i think they like to use the word dynamic range.
Chris
Producer, Engineer,
www.ukmastering.com
Old 12-05-2018, 05:24 PM
I already knew what range does/means and I know it's different from compression ratio. What I don't understand is how one dynamic eq has range and another has ratio and how if any do they relate to each other.
Jack
QAPLA!
Old 12-05-2018, 05:30 PM
Originally Posted by crizdee View Post
Chris
If dynamic range is fundamentally ratio how does one relate to the other? Some kind of conversion factor or what? That's what I can't figure out. It makes it difficult when trying to compare/contrast say the Pro Q3 and HOFA's IQ-EQ with near equal (or as close to equal as possible) settings on both. IOW how can I get equal results out of each without tuning by ear?
Does ratio even have a place in dynamic eq?
Jack
QAPLA!
Old 12-05-2018, 05:55 PM
Is a developer's choice. If you understand Range you will see why.
amagrasmusic.com
Old 12-06-2018, 04:01 PM
crizdee's Avatar
Yeah can be confusing for sure. Dynamic EQ or frequency conscious compression expansion. Much the same thing really. Freq conscious compression mostly uses ratio 2:1 / 4:1 / and so on except brainworx who just use factor (which technically is linear variable ratio) on their dynamic EQ, then the other dynamic EQs mainly use a range ha ha ha
Dynamic range really is just a more or less knob. Once it reaches the threshold set? how much compression or expansion do you want to apply? But unlike a ratio that will stick to its factor of 2:1 / 4:1 / 20:1 or whatever the ratio is set to, the range will just apply more or less depending on the input level. Um a bit like a linear ratio. Oh man let’s just close our eyes and if it sounds good then it is.
Chris
Producer, Engineer,
www.ukmastering.com
Old 12-06-2018, 04:15 PM
Chris
Understood about the latter sentiment. But like I said it makes it difficult to compare two different pieces of s/w if they have the control differences I cite.
Jack
QAPLA!
Old 12-06-2018, 04:17 PM
Best answer
amagrasmusic.com
Dynamic Range of a DAW jayasankarkp Pro Tools 10 4 11-04-2012 09:46 AM
Dynamic Range Day Pinball Wizard General Discussion 0 03-17-2012 11:38 AM
Best Dynamic range in 5.1 mixes ? jessmachine Post - Surround - Video 2 07-29-2010 05:43 PM
Dynamic Range outfit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-15-2003 05:07 AM
dynamic range bjoneill74 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-18-2002 07:55 AM
