Old 10-23-2011, 11:58 AM
Von_Dingle Von_Dingle is offline
Default Master Fader clipping
I'm doing a project for school and my track is clipping only form the Master Fader. Previously, when it clipped, I could scroll down and see, for example, the snare clipping as well. I would just go and fix that and then the Master Fader level would be fine. Now, however, my Master Fader is clipping but no other tracks are. It's just once or twice but very annoying. it seems to be a bad idea to simply bring the level down on the fader itself so it doesn't clip since it affects the entire session that way. How do I find what is causing it?
MAC RIG
Make/Model: ProjectMix I/O and an Avid MBox Mini 3rd gen.
Operating System: OSX 10.6.8 Lion
Processor: Intel Core i7 2.2 Ghz
RAM: 8 GB
Monitors: M-Audio BX5a
MIDI Controller: Axiom Pro 49 and Oxygen 25 3rd gen
DAW Software: Pro Tools 10.3.8
Outboard: UA LA-610MkII and UAD-2 DSP and plugins
Old 10-23-2011, 01:38 PM
The Weed's Avatar
The Weed The Weed is offline
Default Re: Master Fader clipping
You are summing all the tracks into the 2 buss, so all together they are causing the Master to clip, even though no individual track is clipping. If you like the mix - ie how all the tracks together sound - then make a group of your tracks and lower them all together so they don't clip the Master.
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 10-23-2011, 05:10 PM
If its only clipping here and there, simply dragging the master fader down by a db or 2 might solve the clip. Personally, if I can eliminate the clipping by lowering the master less than 3db, that's what I do. If it takes more, then I lower all the audio and instrument tracks instead(by 4-5db). With post-fader fed AUX tracks, those can remain up as the signal fed to them will be lowered already.
Old 10-24-2011, 05:01 AM
SpinningDisk's Avatar
SpinningDisk SpinningDisk is offline
You don't happen to have a plugin on the Master Fader that may cause this?
Old 10-24-2011, 11:47 AM
MidnightFlyer MidnightFlyer is offline
You might also experiment with putting the trim plugin as the first insert on your master fader and bring down the gain accordingly.
[IMG] code is Off
Master Fader is Clipping, what now? Peulock Pro Tools TDM Systems (Mac) 21 03-08-2009 07:06 AM
Master Fader Clipping 4times4mil 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 11-12-2006 01:44 PM
Fixing Clipping in Master in Master Fader pakobo7 Pro Tools M-Powered (Win) 10 09-16-2006 10:53 AM
Master inserts are post-fader? Was: L1+ on Master = clipping s2n Pro Tools TDM Systems (Mac) 10 11-20-2001 07:41 AM
Master fader clipping? brasssail Pro Tools TDM Systems (Mac) 4 03-15-2000 09:40 AM
