Old 04-03-2017, 06:23 AM
Armando Armando is offline
Default Extender for 8 pin mini din crossover cable
Hello, does anyone know of any extender type product to extend 8 pin mini din? I've looked for a CAT5 type extender but couldn't find any.
My Mac is located about 35 ft away from my SYNC I/O. I realize I can run a cable that length but would rather avoid that direction if possible. Thanks!!
Armando
Old 04-03-2017, 10:00 PM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Extender for 8 pin mini din crossover cable
If nothing else helps, you can cut the cable and fit it with DE-9 connectors. Then you can find extender cable of any length you can think of.
Janne
Old 04-04-2017, 08:09 AM
Thanks! I think I'll try this route. I know I need at least on 8 pin mini din crossover cable. I wonder if anyone makes a 8 pin mini din to db9 crossover cable/adapter?
Armando
Old 04-05-2017, 03:55 AM
JFreak's Avatar
This should be easy task for anyone near you that has a clue about electronics and making cables.
Before you cut the wire, you remove an inch of the outer plastic to reveal the wires inside. Then you mark the wires on both sides and cut fromthe middle. Once everything is cut, you just solder the marked wires to DE9 pins 1-8 and repeat on the another end, making sure your male/female connectors connect 1-wire to 1-wire, 2-wire to 2-wire, and so on. Then you connect the DE9 plugs and test the cable.
Once it works just like before the cut, you only need a standard DE9 serial cable of your desired length in the middle.
Janne
Old 04-05-2017, 10:44 AM
I just realized something important. I don't believe these extenders are bi-directional. I don't think it would work this way
Armando
Old 04-05-2017, 09:54 PM
JFreak's Avatar
It's 8-pin serial cable. If you connect all pins, its just as good as a shorter cable, at least as long as the combined cable length isn't too much...
Janne
DigiLink Mini 25' cable? DetroitT Pro Tools HDX & HD Native Systems (Mac) 0 10-24-2011 07:04 AM
Esata extender cable MIKEROPHONICS Pro Tools TDM Systems (Mac) 10 04-05-2010 01:38 PM
16 Channel Y Peripheral Cable extender alschupf General Discussion 2 07-04-2004 05:43 PM
192 aes>Kurzweil ksp8 aes, aes crossover cable? fourthtunz Pro Tools TDM Systems (Mac) 3 07-29-2003 04:42 PM
Can anyone help me find a crossover freq module for my EV XEQ-2 active crossover? ragbor Pro Tools TDM Systems (Mac) 2 11-08-2002 07:45 AM
