Creating stronger Impulse Responses
Hey,
So i'm making some impulse responses from my Space Echo. Comparing it to the Altiverb preset Space Echo IR's. Mine come off sounding quiet, does anyone have any tips for creating a stronger, cleaner IR? Any advice would be appreciated
Pro Tools 2024.3.0|Perpetual MTRX Studio HDX1 Sync-X S3 Dock Mac Mini 2018 - 3.2GHz i7 6-core macOS 13.6 RAM 64GB DDR4 GPU AMD 6900XT 16GB Monitor LG 32UL950-W |
Re: Creating stronger Impulse Responses
Never tried this here, but my instinct tells me that this might be a good use for the Audiosuite Normalize plugin
Cheers for the tip.
I should have clarified my processes. Tracking through: DI - Fethead Phantom - SQN4S Mk4 - R26 Recorder. Into Pro Tools: Edit - Denoise - Phase Rotate - Normalize -1db - Output. So the clips are hot, and clean. But once I import it into Altiverb then process it it comes back as quiet and kind of dull.
Is there any audible difference between Normalizing/boosting with Slate’s “Trim”/or boosting with Clip Gain? Do all end up with the same noise level? Thanks!
Pro Tools Studio 2024.3 * SSL UC-1 * Digidesign Command 8 * M-Audio Axiom Pro 49 * PreSonus Speakers & Monitor Station V2 Last edited by unkJE; 03-16-2017 at 08:58 PM. Reason: same noise level? |
I think it might have to do with the system the OP is using to create the IRs. Make sure you aren't missing any step. Also, since this is a process that works in reverse (as a matter of speaking) perhaps instead of normalizing, what you have to do is the opposite...
This is just me thinking out loud, I've never tried making my own IRs although I might try real soon.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com |
What are you using as your impulse?
That can effect the response you get. McDSP's Revolver comes with tools to create your own responses - although I think it may depend on which version of the plug-in you have (if I remember correctly, either version 4, or maybe 5, didn't include that function in AAX - you had to use RTAS, and possibly it only worked on Mac - it was a AAX + Windows transition issue). Sent from my iPhone using Tapatalk |
I've made impulses from a PCM 80, reverbs and delays etc and got very good results using the 'pop' they provide.
I thought the sweeps were more for room acoustics played back through a speaker?
Mac Pro 7,1 16 core, OSX 12.7.3, HD-Native TB, Trinnov MC, MTRX Studio, 2xRME ADA-4, Sync HD, AJA IO XT, Avid Dock, Avid S1, PT Control, Soundflow, PT 2023.12 |
The pop is for digital processing units, for an analog process you need a sine sweep (according to https://www.audioease.com/altiverb/sampling.php)
Impulse Responses | 2hip2b4real | macOS | 1 | 05-16-2012 08:05 AM |
OT/impulse responses | clusterer | Post - Surround - Video | 4 | 12-03-2009 10:18 AM |
Creating TL Space Impulse Responses (IR's) | doopadee | Pro Tools TDM Systems (Mac) | 0 | 03-28-2007 12:52 PM |
Help!!! Impulse Responses? | JeremiahC | Pro Tools TDM Systems (Mac) | 2 | 01-27-2005 11:48 AM |
my impulse responses | Chris Cavell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 07-04-2004 08:08 AM |
