EuControl 3.3.1
anyone running this on mac OSx 10.8.5 without issues? have been running 3.2.2 in 10.8.5 but have been having issues
Cory Rizos, CAS Re-recording Mixer/Sound Designer Montreal, Quebec http://www.imdb.com/name/nm0007185/ coryrizos.com |
Re: EuControl 3.3.1
Yes running Eucon 3.3.1 and PT12HD on OSX 10.8.5 rMBP 2014 and have no issues so far
Re: EuControl 3.3.1
Thanks...
can anyone else chime in whether this Will work with protools 10 or 11...not just 12... Cheers
Re: EuControl 3.3.1
If i remember correctly on spec-sheet Eucon 3.31 should run w/ min pt 11.3.2, and pt 12.1 ,and osx 10.8.5 is compatible w/ both. Goodluck
Re: EuControl 3.3.1
Thanks...
Re: EuControl 3.3.1
I'd like to know too.
I'm running OSX 10.8.5, Protools 10 and trying to get all the pieces together for Protools 12. Eucon 3.2.1.... runs OK with PT 10, but PT 12 crashes it every time. I don't want to update to 3.3.1 until I know I can still run PT 10 with it.
HD Native, Omni, BlackMagic Intensity, i9 9900, 32GB Ram, Windows 10 pro PT 2020.5 www.TakomaMedia.com |
Re: EuControl 3.3.1
Agreed - would like to know if Eucon 3.3.2 is compatible with both PT10HD and PT12 HD on osx 10.8.5
Re: EuControl 3.3.1
We have installed 3.3.2 on HD12 10.8.5 and we get error at installation and crashes and errors using Eucon, obviously it is designed for the newer OSX versions so you can try and hopefully your system works.
Re: EuControl 3.3.1
I bought a Artist Mix for 700 from a defunct studio. He cranked it up and showed me it worked. He moved away and I have no way to contact him I go to download the drivers and it prompts me to register. I can't register because it's already in the database. Then I look up and it says I wont be able to register because it is second hand. I have to fill out a Transfer form? Who is AVID to say whether a person can or cannot sell their stuff? I understand not offering free support but at least allow me to download the drivers! I am stuck with a console I cannot use because Avid wants to get paid for someone selling their stuff to me since the Transfer form has a cost attached. This is ridiculous and robbery! Is there a way I can get the drivers so I can use what I bought?
Re: EuControl 3.3.1
I've installed 3.3.2 on 10.8.5 and running both HD 10 and HD 11 and its works well. I'm not getting any crashes. Have not taken the plunge to install HD 12.4 on mountain lion.
I installed 12.4 HD on Mavericks with 3.3.2 and its works way better than previous version. keep in mind there are now missing key commands! like Write to all Enabled is no longer working via a key command you have to use the pull down menu!
Eucontrol & Cpu | jky | Artist Series | 2 | 10-30-2016 09:38 AM |
Where to get Eucontrol 3.2.1? | dumbeat | Avid S1, S3, Dock and Control App | 5 | 04-12-2015 03:08 PM |
EuControl 2.7 now available | Avid | Technical Alerts | 0 | 02-28-2013 04:17 PM |
EuControl | Trazan | Artist Series | 3 | 12-13-2011 12:57 PM |
EuControl PC / | davidcl | Artist Series | 3 | 12-27-2010 05:02 AM |
