Old 04-15-2003, 01:09 PM
Rockman-Songwriter Rockman-Songwriter is offline
Default PT 5.1 - Recording very lengthy narrative project.. ran out of recording disk space?
Hi everyone,
I'm trying to transfer 3 cassettes (yes... that pre-historic format) into Pro Tools. Each cassette is 90 mins. It's all narrative stuff. At some point, I always get this prompter saying "could not allocate space for recording", and it stops recording. Meanwhile, my Preferences-Operation-Open ended record allocation.. is set to "use available disk space". I originally thought my cheetah 9 gig drive might have been full, so I copied the whole folder over to my firewire drive (100 gigs of space), and it still is giving me that prompter.
Any ideas? Is there a limitation to how much audio can be recording per session? Is there a special mode for such types of projects?
Thanks
Old 04-15-2003, 01:17 PM
Jeff Schmidt Jeff Schmidt is offline
Default Re: PT 5.1 - Recording very lengthy narrative project.. ran out of recording disk space?
It means your disk is heavily fragmented and Pro Tools can't find enough CONTIGUOUS hard drive space to continue recording.
Use Norton or other tool to de-frag your HD and try again.
[img]images/icons/wink.gif[/img]
2019 Mac Pro 7,1
192 GB RAM
Catalina OS 10.15.7
PT Ultimate, or whatever 2022.6 is called now
HDX 2 w MTRX, Dadman
9.1.4 Dolby Atmos over Dante to external RMU
Old 04-15-2003, 01:22 PM
Thanks Jeff. Umm.... but my firewire drive is brand new. And when I tried to work off of it, it still gave me that problem. And it has about 85 gigs of free space. Any other input?
Thanks
Old 04-15-2003, 01:37 PM
Change your open ended allocation to 120 minutes.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 04-15-2003, 04:01 PM
Ok. I'll try it. Thanks again.
Old 04-15-2003, 11:45 PM
BMann BMann is offline
This situation may not apply but be aware, if PT crashes in record the pointers remain at full disk allocation, meaning that everytime you reload the session it will see the HD as being full, and a prompt will come on when you try to record "this disk is full".
Check the drive in the finder and see if there is SDII file that has a "huge" file size, this is the crashed data. If so delete that data and start over.
This may not be your problem, then again Maybe!
WM
Old 04-16-2003, 12:32 AM
tubajay tubajay is offline
I have been having a similar problem with my 18 gig cheetah - with having allocation set down as low as 3 minutes and still "PT could not allocate... " Both 9 gig HD's work flawlessly....Never ever had this problem before upgrading to 5.1.3 (from 5.0.1) [img]images/icons/frown.gif[/img]
Jay
PlugHead Productions
Could Not Allocate Disk Space For Recording ztaylor9632 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 08-30-2011 12:34 PM
Pre-allocating disk space for recording 1m1 Pro Tools TDM Systems (Mac) 4 05-04-2004 09:14 AM
'Cannot allocate disk space for recording' greenroom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 08-12-2002 07:31 AM
"Could not allocate disk space for recording" yonkiman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-02-2000 01:13 PM
"Couldn't allocate disk space for recording?" dBHEAD Pro Tools TDM Systems (Mac) 3 10-19-1999 12:41 AM
