Multiple Audio Suite windows?
Is there any way to have multiple Audio Suite plugins open in the way you can with TDM plugins?
(Pretty sure the answer is not but ...)
PT2020.5.0 / HDN / HD Omni / MC Control / Intensity Pro / Catalina / 3.7 Quad core Intel Xeon ES (trashcan) MacPro / 12GB RAM Over 30yrs experience in pro-audio - mostly for picture. |
Re: Multiple Audio Suite windows?
Correct!
As audiosuite is processing to risk, it would be a bit confusing having more than one disk rendering process occurring. guess thats why we can't have more than one open!! You can of course hold apple whilst selecting any plugs and they will reside in the top of the menu as your favorites etc Chris
Not sure it would be that confusing - you can only hit one "Process" button at a time. It would just be nice to be able to have a couple open if you're using them every couple of minutes. Never mind.
I recently noticed that I can have different AS plugin windows open under different window configurations. You can use a shortcut t switch between window configurations.
Dmitri A. Chernov re-recording mixer/supervising sound editor/studio owner Moscow, Russia http://www.imdb.com/name/nm2555539/ |
I think it would be great to be able to have several AS windows opened at once. In fact, there should be user definable "sets" of AS windows. For example, if one is working on DX restoration, one could have a set that with one mouse click opens: duplicate, gain, Izotope hum removal (or similar), EQ (sharp filters), Izotope de-noise, and Oxford de-cracke, Izotop de-click. This way, one could use which ever of these processors is needed (as as many as needed) but they would all open with one click on a user defined set called "AS restoration". I think this would be very helpful even if one is processing one plug at the time. But most importantly, we need AS handles.
Exactly my thoughts Garnoil. (Right down to the plugins and purpose.)
where do i sign
...me failing english? That's Unpossible _____________________________________ |
+1 on the request. Has anyone put that on Ideascale (not that it really makes a huge difference).
You can have multiple AS plugin windows open now. Just hold Shift when adding more plugins.
Surely this works for all plugins instantiated as inserts. Pressing shift "anchors" the plugin window. But it doesn't work on audiosuites. At least not on my mac.
multiple audio suite effects | bbbkink | Windows | 8 | 02-05-2013 05:34 PM |
Recording multiple midi drum channels to multiple audio tracks? | ewan.mcghee | MIDI | 7 | 07-18-2011 01:46 PM |
Multiple audio suite plug ins Open. | kd_special | Pro Tools 9 | 7 | 12-18-2010 11:54 AM |
PT 8.0.4 on Windows 7 Audio Suite crash | TMT | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 09-15-2010 01:08 PM |
Multiple Audio Suite Window's | Daveyr2 | Pro Tools TDM Systems (Mac) | 14 | 11-02-2009 06:53 AM |
