Old 12-21-2016, 10:44 PM
Barry Johns Barry Johns is offline
Default Re: broken HD Core Accel card and nearest Digidesign Technical Support Office
Originally Posted by [email protected] View Post
What resistor did you end up using? From my search I'm, looking at:
10k 1 % 1/8W 75 V
1608/0603
Or is the case code 2012/0805?
I have a couple of bad HD Pcie cards if it helps for parts.
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors.
MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp
Old 12-22-2016, 08:31 PM
jdleyden jdleyden is offline
Barry,
I'm looking for the resistor that goes in R35, just want to make sure I get the right one before I bring it in to my work and use their PCB soldering station.
Old 03-06-2017, 11:45 AM
SoundVillageStudio SoundVillageStudio is offline
Hello, when i launch Protools appears DAE error -1115 and my ProTools HD 8 can't start...
My system is HD 1, with 1 Core Card PCI-X and 96 I/O
Digitest doesn't recognize any pci cards
is the card?
Is the 96 I/O?
is the snake link?
Please help me, best regards
Old 03-06-2017, 11:47 AM
Drew Mazurek's Avatar
is the card?
Is the 96 I/O?
is the snake link?
Start by "exercising" everything. In other words, unplug everything, pull out the card, vacuum or blow out any dust etc, then put it all back together.
Sometimes reseating everything can knock loose dust or minor corrosion.
www.drewmazurek.com
Old 03-06-2017, 09:34 PM
JFreak's Avatar
JFreak JFreak is offline
Yes. And this should be done more often than only when something is not working. The box has pretty good AD conversion but audio has to come through those grey ribbon cables which are notorious for bad connectors.
(in a perfect world it would be soldered but as it makes servicing much slower there has to be some quick way to unplug it -- so there we are, have to reseat connectors every five years)
Janne
  #16
Old 03-07-2017, 01:51 PM
I've do all of those precious tips, and so i removed the card from slot, clean etc.
I have also changed the slot PCI, putting the card in another one...but nothing is changed. Digitest doesn't recognize anything.
How can i be sure that the problem is the card? Maybe the 96i/o or the slot PCI of my computer?
I wanna learn more about it....if someone know please tell me...
My best
  #17
Old 03-07-2017, 11:24 PM
JFreak's Avatar
Remove all cards from the computer and use little alcohol-based cleaner to clean the PCIe connector (perhaps little alcohol-based beverage for you as well). Then re-seat the core card only. If it was a bad connection, it should now have been fixed. You can try for another slots as well, but I don't think that a slot suddenly breaks if the motherboard is otherwise functional.
If the digitest doesn't recognise 96 i/o and it powers up, you might have a faulty digilink cable.
Janne
  #18
Old 03-08-2017, 09:21 AM
Thank you for the time you spending to me, in my mac (hackintosh with OS 10.5.8) if i select: [finder>info about my mac>hardware>slot pci] it appears a message: no pci seems to be installed.
And...
I'll read better the guide, but i don't find any digi 96 test.
P.s. i remember you that is a Core Card PCI-X, not a PCIe.
Thanks
  #19
Old 03-08-2017, 09:36 AM
JFreak's Avatar
PCI-X or PCIe it doesn't matter, the digitest must see it
Janne
  #20
Old 03-12-2017, 01:08 PM
Thanks, digitest doesn't recognize the core card...any other test to suggest me?
PT HD1 (core card PCI) x PTHD1(Accel core card PCIE) Alécio Costa Pro Tools TDM Systems (Mac) 6 05-02-2017 06:52 AM
FS: Digidesign HD Core Card and Accel Card - PCIX/PCI N1h1l1ty Buy & Sell 7 05-30-2015 10:35 AM
Digidesign Technical Support onepercentfree 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-02-2009 06:59 PM
Digidesign Technical Support Line cetanorak 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-16-2009 04:00 PM
what is up with digidesign technical support kraaag 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-12-2004 04:57 PM
