Old 07-29-2010, 06:10 AM
david kowalski david kowalski is offline
Default Export regions(Shft-Cmd-K) command is acting strange
PT HD 7.4.2. G5 PPC dual core 2.1 ghz
I have been having a problem with the "export regions" command
(Shft-Cmd-K).
For example, if I highlight a series of regions in either adjacent or sequentially in the same track and export them to , let's say, stereo wav files for cd burning, the result is either random unrelated regions from that session, (not even from the same track) or in some cases, only one of the selected files even though multiples were selected.
Also, Only once was I able to export properly and only after a full computer reboot, and only on the first attempt after rebooting. Subsequent attempts returned to the malfunction described above.
Has anyone experienced this?
Old 07-29-2010, 06:38 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Export regions(Shft-Cmd-K) command is acting strange
(Shft-Cmd-K).
Is this on one specific session or is it the same on all sessions? could be session corruption! if so, try using save copy in to create a new session.
also try all the usual trash prefs and database files etc.
use this app... http://duc.digidesign.com/showthread.php?t=190122
Chris
Producer, Engineer,
www.ukmastering.com
Old 07-29-2010, 08:23 AM
Chris,
I did trash prefs, but not databases.
I'll use the app and see what happens, thanks.
This anomaly occurs on any session, not just one in particular.
Dave Kowalski
www.davidkowalski.com
Old 07-29-2010, 03:34 PM
Cheesehead Cheesehead is offline
This has also been acting strangely for me for a little while too, When I export an interleaved stereo Wav file, I also sometimes get mono left and right ones too. Seems fairly random whether it happens or not.
Any ideas please?
PTHD 8.03 Mac Intel quad core Osx 10.6.2
Old 07-29-2010, 04:35 PM
Make sure "Region List selection follows Edit Selection" is enabled... after trashing your prefs.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 07-30-2010, 02:13 AM
tj_davies tj_davies is offline
Rail
...also, always press Shift+Cmd+D before exporting. If you have recorded and then renamed the file, Pro Tools doesn't update the region list properly. Shift+Cmd+D does that for you. Then select the files, export and you should be fine.
Hope this helps,
Timothy
Mac Studio Ventura 13.6
PT 2020.12.0
www.pearls-music.com
Old 07-30-2010, 02:22 AM
Any ideas please?
PT will only export multi-channel-files correctly when they have the correct suffixes. So when you drag two independent mono-files to a stereo track (from an OMF export for example) and then export that PT will write two mono files even when you set it to export "stereo".
To avoid that you fist have to consolidate over that clip or rename them manually.
Frank.
Old 07-30-2010, 03:24 AM
Just a quick video (click here), that shows this little bug. And that Shift+Cmd+D helps getting rid of it.
This seems only to happen if you rename the regions by double-clicking on them. At the end of the video (Files E and F) I rename by using the shortcut Shift+Cmd+R. That way Pro Tools doesn't seem to create two mono files in the region list.
It also has something to do with file sorting by modification date and descending (these are my settings anyway inside the region bin - as that way, I will always have the last imported audio files on top).
Maybe this helps,
Timothy
PT 2020.12.0
Old 07-30-2010, 04:33 AM
Thanks for all your replies and suggestions. I tried re-opening a session it had just happened to me in to test out the Shift command D thing and bizarrely I can't get it to do anything but what its supposed to now!!
Maybe closing and opening the session resets it somehow?
Anyway I'll try the method in the video when it happens again, as I'm sure it will. Maybe it does have something to do with sorting the region list by file modification date. I do that too, so my SFX come in at the bottom.
Thanks Again and sorry for hi-jacking the original posters thread. Hope he gets his problem sorted too.
PTHD 8.0.3 cs2 Mac Intel quad core Osx 10.6.2
Old 07-30-2010, 04:42 AM
...bizarrely I can't get it to do anything but what its supposed to now!!
What exactly is not working anymore?
Then maybe try renaming with the shortcut (Shift+Cmd+R). By the way, jumping to the next region is Ctrl+Tab, if you want to rename several files.
Or select all regions and press Shift+Cmd+R - but be aware, with sorting by file modification and descending you name the last recording first (obviously first recording last!)
Maybe this helps,
Timothy
PT 2020.12.0
RE: Export Selected (Cmd+shft+k) sometimes doesn't work alex s 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-09-2016 10:22 AM
003R acting strange? Holly73 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 12-16-2008 02:46 AM
Need Computer Help, G4 Acting Very Strange! johnjm22 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 08-28-2005 03:56 PM
Help! MBox acting strange... KDK Twelve 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-13-2004 02:44 PM
HELP!! DIGI OO2 ACTING VERY STRANGE! johnjm22 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 09-28-2004 04:00 AM
