Old 06-28-2006, 07:08 PM
Mr.BossPlaya Mr.BossPlaya is offline
Default Vocal Booth
I was wondering if anyone had a guide or DETAILED instructions on constructing a vocal booth. Something about 4-5 ft wide and deep, and about 7 ft tall. Just big enough to track one vocalist.
Thanks!
Old 06-28-2006, 08:09 PM
Craig F Craig F is offline
Default Re: Vocal Booth
other than how bad it would sound no I don't
Thank you,
Craig
Old 06-29-2006, 03:39 AM
NickH NickH is offline
This forum is great for this kind of thing:-
Here
I did all the research & plans once, to do it right I would have lost half the room...
N
“It’s because you touch yourself at night... ”
System Specs
Old 06-30-2006, 09:09 AM
DeNiro DeNiro is offline
I personally think the booth thing is over-rated due to modern technology. Mics with new directional fields cut out on alot of unwanted noise. A room the size of a closet with the corners sound proofed would make for a decent recording. The corners are the only things that will kill your desired sound. Another thing is where your located. If you are recording somewhere near a street or train station, etc., then you will need to secure the 6 boundries of sound.(Up, down, sides, forth and back areas.) Other than that consider power conditioning. Think about it; when was the last time a consumer(our bosses) said "Did u hear that background noise?"..One last thing: Compression. Hollatchaboi!
Old 07-04-2006, 08:33 AM
daeron80 daeron80 is offline
Craig F is right - a room that small is going to sound awful. Treating the corners is only going to address one of a hundred problems inherent in small vocal booths. There are also severe modal anomalies well into the lower mids, comb filtering in the upper mids, a complete lack of the crucial initial time-delay gap, and no distinction between early reflections and reverberance. If you need that much isolation so badly that you're willing to have your vocals sound like they are in a tiny, dead space, then you must do what you must do. You're probably better off pointing a tight-pattern mic (414s are great for this) into a corner from a few feet away, padding the corner and ceiling a bit, and living with whatever bleed gets through.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Vocal Booth? Bart HLH General Discussion 5 03-02-2007 05:48 PM
how to build a vocal booth? wreckthisplace General Discussion 1 12-12-2005 10:28 AM
homemade vocal booth optymusblu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 08-24-2003 06:16 PM
Vocal booth SKI Pro Tools TDM Systems (Mac) 7 03-23-2003 12:05 AM
Vocal Booth smrp Tips & Tricks 5 05-31-2000 01:06 PM
