NI Komplet 8 don`t show in PT12
I updated my NI Komplete/Kontact to the latest 64 Bits version but still don`t see it im my PT 12 ... I only see Reaktor.
Other NI/PT12 users with the same problems ? |
Re: NI Komplet 8 don`t show in PT12
Members Musicman691 and unkJE are great at these version questions as we have NI KU11 now which works great with PT12HD so I have never used any version of the NI ultimate versions below 9.
I think it was after Komplete 9 was released that NI released the AAX64 plugin versions. But some of the individual plugins within earlier versions of Komplete have updates that the OP should have access to.
This NI page https://support.native-instruments.c...in-KOMPLETE-8- Shows Kontakt 5 and Guitar Rig 5 as new. And this review by musicradar ... http://www.musicradar.com/reviews/te...plete-7-283544 Shows Absynth5, FM8, Massive and Reaktor5 included. So the free updates to all those listed above should give AAX64 compatility to these plugins from Komplete 8. The only question mark in my mind from that list is Reaktor ... I seem to remember there being a paid upgrade needed to get AAX64 unless you upgraded Komplete to version 9, then it was included. Reaktor 5.6 comes to mind. I can't remember if Battery 3 was ever AAX64 compatible, but Battery 4 was first included in Komplete 9. OP ... Have you installed the latest plugin updates available via Native Instruments Service Centre? Can you list which update version numbers you have installed?
Mac Pro 2009 with 2010 firmware, 12-Core 3.46ghz, 64gb RAM & working Thunderbolt, OS 10.14.6 and Windows 10 iMac 2012 27", 3.4ghz i7, 32gb RAM OS 10.14.6 Digi 003 Console for control surface only, Focusrite OctopreLE and MOTU Traveler for extra analog-ADAT conversion, UAD Apollo Quad Silver with Thunderbolt card, Apollo x4 and pci-e Octo, Adam A77X monitors. Pro Tools 2022.4, Media Composer 8.9, Sibelius 8.7, Cubase Pro 11, Wavelab Pro 11, Logic Pro X 10.5.1, Mainstage 3. Various apps, soft synths, FX plugins. Plenty of hardware synths, rack gear, microphones etc. And then there's the studio ;-) |
What exact versions of the various NI plugins do you have? On this page is a partial listing of NI plugins that support aax64: https://support.native-instruments.c...s-11-or-Higher |
Battery 3 is not aax64 compatible; that happened in Battery 4.
Most of Komplete 8 works just fine with PT12 as AAX64 plugins here. Battery 3 won't... because AAX64 is supported until Battery 4.
Installing everything straight from the DVDs alone won't work. You need to run NI Access or download the most recent updates from NI after installing from the DVDs to get AAX support. Even then, I think I remember needing to click the 'customise' button on the installers under OSX and manually 'checking' AAX for it to install.
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command. |
AAX64 support wasn't in the original release of Battery 4 - that came in an early update. |
But that meant the AAX64 versions were deselected too. We had to manually select to install the AAX64 versions. Then, subsequent updates knew which plugin types we wanted. So the OP may have installed updates that include AAX64 versions, but if he didn't actually go into 'customize' and select the AAX plugin type, they won't have been installed. Well remembered LDS
You can upgrade your NI komplete to a version above 9.
You can, but whether it is worth the money depends on whether you want those extra Kontakt sample libraries.
Absynth, FM8, Guitar Rig, Kontakt are Massive are still at the same version (there haven't been any paid updates) as they were in Komplete 8. Battery was updated to version 4 and was included in Komplete 9. Only Reaktor has a new paid upgrade (to version 6) that is included in Komplete 11. So upgrading to Komplete 11 is only worthwhile if you need the extra Kontakt sample libraries. Personally, I upgraded to Komplete 9 ultimate, as I was previously at Komplete 6, but I haven't seen enough new stuff in Komplete 10 or 11 that would be interesting to me. My next Komplete update will be at Komplete 12. Why? Well Native Instruments update pricing is the same for several previous versions. Currently updating Komplete Ultimate is the same price if you want to update from version 8, 9 or 10. I'm guessing that when Komplete 12 is released, it will allow updates from 9, 10 or 11. And there will be a bigger range of 'new' Kontakt sample libraries when compared to Komplete 9. So it is more worthwhile. To stay current, I'll need to upgrade then, otherwise my Komplete 9 will potentially become not updatable.
PT12 Mixer Window Wont Show | pete_g | Pro Tools 12 | 5 | 01-28-2017 03:24 AM |
Opening oversized PT12 HD session in non-HD PT12? | mjpatey | Pro Tools 12 | 6 | 01-10-2017 09:25 AM |
Velvet - virtual instrument won't show up in PT12.5.2 | Atlanta Bliss | Pro Tools 12 | 7 | 08-18-2016 01:34 PM |
Loading show files in SHOW mode? | fohluke | VENUE Live Sound Systems | 2 | 03-29-2012 11:46 AM |
Pro Tools/D-Show standalone integration idea with D-Show show files/virt. soundcheck | digidesigner | VENUE Live Sound Systems | 2 | 11-08-2011 02:52 PM |
