Old 02-04-2011, 10:15 PM
theblotted theblotted is offline
Default Clear Peak/Meter shortcut not working?
the shortcut is Option + C.
i recall back in PT7, i can do this shortcut key command, and it will clear the meter (pk) every time. now sometimes it wants to do it, sometimes it won't.
what gives?
Old 02-06-2011, 12:18 PM
Default Re: Clear Peak/Meter shortcut not working?
bump
Old 02-06-2011, 12:34 PM
OddsAre OddsAre is offline
Option+C works fine to clear my peaked meters... are you sure OSX isn't using that command for some function?
Mac Book Pro Retina 2.6 GHz i7 Quad | 16GB | OSX 10.8.5 | Digi 002 | Apogee Rosetta 800/96 | PT 10 | Waves Gold/RevMaxx V9
Old 02-06-2011, 03:37 PM
yeah pretty sure.
mind you, that i'm not talking about when something is peaked (red). i'm talking about just clearing the meter in general (in the "pk" field on the Tracks), e.g., if meter shows -15.2 after playback, hitting Option+C should make it go back down to -∞.
looks like it's only working everytime when the track is peaked (red).
OddsAre, did you test this for both PT7 and PT9? i'm using PT8 at the moment.
Old 02-08-2011, 11:40 AM
nobody else encounter this?
Old 02-08-2011, 12:21 PM
1m1 1m1 is offline
It's works the same way on my rig. It only clears the red "overs". I option click on the meters to reset them.
Old 07-22-2011, 06:01 AM
Oleef Oleef is offline
I noticed that when I have red "overs", hitting Option+C will clear the overs, AND it resets the pk´s on tracks to -∞.
(Well, almost. One track in my current session sometimes goes down to -136 or something, the rest goes to -∞)
When nothing has peakt, nothing happens. No pk is reset. For that I use, as others have said, Option+MouseClick on the pk field.
But the red overs in the plugins don´t go away with Option+C. Is there a keycommand for that?
Old 07-22-2011, 05:14 PM
Oleef, it's plug-in dependent. if i'm not mistaken, you can clear overs with at least Digi and Waves plugins, but not on others.
Old 07-23-2011, 02:46 AM
It is mostly Digirack and Waves plugins I use. But I can´t get their peak overs to reset, all at once.
Option+C only clears all track overs, if there are any. Not plugin overs.
Alt+clicking the peak inside the plugin does not reset other plugins peaks. Not even on to Digirack EQIIIs.
Is there another way to handle this? I have tried to search the DUC, but can´t find a key command or other shortcut for this.
I´m using PT9.
(And by the way, I see that theblottet said what I indicated, before me. Sorry for the repeated info)
Clear selected clips shortcut not working hd 10.3.2 dgoodi22 macOS 7 02-08-2013 04:49 PM
Signal peak/distortion/db meter peak when recording enabling track on Pro Tools LE 8 hotgravy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-30-2012 10:49 AM
which peak meter? evs Post - Surround - Video 8 09-04-2008 09:48 AM
Keyboard shortcut to clear red clip lights? kirkbross 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-02-2008 10:36 PM
LED METER PEAK HOLD Gaffer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 02-19-2002 10:07 AM
