HOW TO STOP Protools changing audio interface automaticly when another is connected
GUYS Tittle says it all,
now Im working with dp majority of the time, and using some Motu and Digitech stuff, problem is. that when I connect another usb interface to the mac when I go and open protools it detects automatically the new interface and changes to it... thing that I don't want to happen... cant find anything in the manual, some help would be nice. ^^ |
Re: HOW TO STOP Protools changing audio interface automaticly when another is connect
Best solution is to leave everything connected and make sure the interfaces are powered ON before the computer finishes booting
impossible... we are on the go and connecting and disconnecting everything like 30 times a day... I guess its time to learn to do with DP or Logic what I do faster with protools...
I don't get Why would you want Protools to change any basic settings by itself, there must be a reason I suppose, but I cant see it... Thank you anyway |
I too found this to be a problem, but not just with Pro Tools. I also use MOTU interfaces at home, and have an Eleven Rack. Every time I would wake the computer, the Eleven Rack would become the primary interface, something I did NOT want to have happen. I ended up just unplugging the Eleven Rack from USB and running it digitally into the SPDIF interface of my MOTU interface. Much simpler that way, but it does require me to make all my Eleven Rack adjustments from the front panel (I have it set to follow clock from the the MOTU Interface.)
Don't know if there is a way to order the different interfaces so it does not change.
Save early and often! (or once a day whether you need to or not...) |
I always press the N key during launching Pro Tools to get the Playback Engine window up on start.
My ears! My ears! clausiii ----------------- MacBook Pro i7 Quad 2.6GHz 16GB RAM ProTools 2020.11 Avid S1 Avid Dock Avid Control Digidesign Command|8 macOS Catalina MOTU 4pre MOTU Track16 Axiom Pro 25 LinnStrument 128 Roli Seaboard Block tons of stomp boxes tube amps guitars noise |
changing from protools 8 audio only to protools 8 with video support | djkaz | macOS | 5 | 09-04-2013 04:00 PM |
using pro tools 10 without interface connected | danbeaudoin | Windows | 0 | 10-26-2012 03:28 PM |
Why do my F keys stop changing tools? | evanbenjamin | Pro Tools TDM Systems (Mac) | 15 | 01-28-2012 01:05 PM |
panning in Reason not working when audio interface is connected | violent vickie | Pro Tools M-Powered (Mac) | 0 | 11-15-2011 01:15 PM |
Why do my F keys stop changing tools? | evanbenjamin | Pro Tools TDM Systems (Mac) | 1 | 05-19-2010 04:12 PM |
