  #81
Old 05-21-2015, 04:20 PM
jamieguitar jamieguitar is offline
Default
I'm not sure if anyone said this or not. I didn't want to read the whole thread to find out. However, if my fix works for someone so they don't go through the hassle I did, then good.
  • Open Eleven Rack
  • When it sits in the task bar and won't come up, go to task manager, right click on Eleven Rack and click bring to front
  • Close Eleven Rack
  • Open Eleven Rack
  • When it still doesn't work, repeat this process
  • Repeat it a third time if needed.
This is an insane solution and makes no sense to me why this would work. However, after doing it THREE times, it now opens normally and (so far) has done so about 6 times.
Thank you to cdvh5150 , the person on the first page of the thread for leading me down this road. Only thing different from his solution was to repeat the process.
Jamie Ward
  #82
Old 05-31-2015, 12:18 PM
lvsranch lvsranch is offline
Default
I have to mess with the task manager every time I load the editor. Ever since I installed it it has been a problem. I just keep hoping Avid will do something sooner or later. It is a definite bug, and a big one. A year and a half and counting.
  #83
Old 08-05-2015, 10:48 PM
BorsingStudios BorsingStudios is offline
Default Eleven Rack goes off all Three screens
POOF!!
Just "finished" our clean Win 10 installation on our new HP Z 640 Workstation.
Most stable Win installation I've ever made still some issues remain of course, like when I installed my Eleven rack drivers which enabled my Eleven Rack hardware to be used. Then after I installed the standalone Eleven Rack editor all kinds of Industrial standardization happened because it simply went of all Three screens, Deep into Cyberspace for real. Perhaps to join our ProTools 11's fate since we got fed up with all the "Sorry ProTools needs to restart the Computer BS and switched to Samplitude pro X2 (and Yeah baby, finally a DAW that won't stick it's BIG nose between me and my work)..
Still it would be NICE to get help with the 11 Rack editor.. Without paying for Avid's Industry standard "Support"..
Sir Carl's Evil Twin..
  #84
Old 08-06-2015, 09:33 AM
Benoni's Avatar
Benoni Benoni is offline
Default Re: Eleven Rack goes off all Three screens
Are you saying the 11R Editor is not showing on screen?
Have you tried this?
http://avid.force.com/pkb/articles/e...s-systems-only
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
  #85
Old 08-16-2015, 05:21 PM
[email protected] dave420@hotmail.com is offline
Default trouble with rack editor
hello im having trouble with my 11r editor. it loads up then disapears...
  #86
Old 08-21-2015, 12:31 PM
rpossum rpossum is offline
Default Re: trouble with rack editor
http://duc.avid.com/showthread.php?p...58#post2193958
unfortunately, it seems Avid has left us out to dry and hasn't updated anything for 11r in YEARS.... but there is a way to get the editor back
Let's all encourage Avid to do the right thing and fix some of these basic bugs (and put the 11R window back into Pro Tools!!!!)
  #87
Old 08-30-2015, 05:03 AM
claudetl claudetl is offline
Default Re: Eleven Rack Editor window dissapears
you have this solution but not possible to download , i don't know why .
it shows me privilege not sufficient
Application launcher that will put the Eleven Rack Editor window in the center (thanks to APAC Moderator "Shan")
http://duc.avid.com/showthread.php?p=2143138
  #88
Old 09-17-2016, 03:51 AM
sid_monroe sid_monroe is offline
Hi, I Had this problem too, I don't know if you found a solution, but all is explicated here
http://avid.force.com/pkb/articles/T...s-systems-only
It worked for me.
  #89
Old 09-17-2016, 03:26 PM
martinaston martinaston is offline
It worked for me.
Thanks for this
Eleven rack editor freezes baribari Eleven Rack 2 02-17-2014 07:40 AM
Eleven Rack Editor Now Available Avid Technical Alerts 0 01-23-2014 09:02 AM
Eleven Rack window responds to changes on Eleven Rack, unable to record. pine Eleven Rack 6 08-02-2012 07:50 PM
Eleven Rack and Eleven Rack control window not matching 11R Newbie Eleven Rack 3 04-18-2012 06:07 PM
Eleven rack stand alone editor Samscasa Eleven Rack 23 02-27-2012 08:45 PM
