Re: Eleven Rack Stand Alone Editor Help!
How did you think of that Task Bar idea? I would have never thought of that.
Thanks. I'm trying to figure out why this may be happening, but I still have no idea
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
Jchris i have no clue how i figured that out.. I just took a chance when i opened the task manager to close the program
Benoni you welcome.. Thank you for the you videos about connecting the eleven rack to spdif to reamp, those videos helped me so much... Your the man... The only other problem i have is when i start the Eleven rack editor than start pro tools 10.3.8 the editor works but my M-Audio project mix which is connected as the main interface n the eleven rack is spdif external ,the project mix works n records but the faders n displays dont communicate with pro tools.
Than if i start the project mix m pro tools without the editor, the M-audio project mix loads n communicates good with pro tools and the faders work n the displays shows the right track names but the Eleven Rack editor wont load... I hope you undersrand this n have other people with this problem... |
Opps i meant youtube...
#16
Hi, I tried this suggestion for a fix on windows 8 and it didn't work. When I first installed the eleven rack stand alone editor I didn't have any problems with the program working properly, then the next time I went to open it the minimization occurred and now nothing seems to work to get the editor to show properly. I have uninstalled, reinstalled, completely removed the program from my computer and downloaded the program several times to see if there was something wrong with my download, although I don't see how the download could be the problem, I was just trying everything possible in the trouble shooting department, and still the program stays minimized. Personally it makes no sense that a program can work one day and not work the next when no changes have been made in any way. Please let me know if there are any other suggestions to get the eleven rack stand alone editor to work properly. Thanks.
#17
#18
I specifically loaded Pro Tools to use with the eleven rack on this particular computer to be able to take it with me and not worry about a $1000+ computer getting damaged when out and about, and I haven't had any problems using Pro Tools or the eleven rack with this computer. The thing is that the virtual version of the eleven rack works just fine on the computer when running pro tools 10, runs pro tools 10 and 11 just fine also and the eleven rack editor was working properly when first installed so I don't see the computer being the problem. I believe that if the computer was the issue then I wouldn't have been able to run the eleven rack editor from the start, which wasn't the case, as I have stated the program was working properly at first. I haven't downloaded any other programs or changed anything with the computer from the time of initially downloading the eleven rack editor and using the editor without opening Pro Tools 10 for the virtual eleven rack. I am able to open Pro Tools 10, the virtual eleven rack opens and is functioning properly so at least this issue with the eleven rack editor isn't effecting the workings of the other programs. |
#19
#20
just using the standard windows display settings, through the control panel or right clicking the desktop for the screen resolution / personalize options.
Eleven rack editor freezes | baribari | Eleven Rack | 2 | 02-17-2014 07:40 AM |
Eleven Rack Editor Now Available | Avid | Technical Alerts | 0 | 01-23-2014 09:02 AM |
Eleven Rack window responds to changes on Eleven Rack, unable to record. | pine | Eleven Rack | 6 | 08-02-2012 07:50 PM |
Eleven Rack and Eleven Rack control window not matching | 11R Newbie | Eleven Rack | 3 | 04-18-2012 06:07 PM |
Eleven rack stand alone editor | Samscasa | Eleven Rack | 23 | 02-27-2012 08:45 PM |
